petcock question
- kz1k
- You Cant Fix Stupid!
1978 KZ1000A2
- Thank you received: 2098
Vacuum tube attaches to highest petcock nipple;
2 lower petcock nipples are fuel outlets.
No fuel should be allowed to reach carbs without first passing through an aftermarket in-line fuel filter.
Where carbs have dual fuel intake tees, should be a separate fuel line to each tee (i.e., 2 fuel lines from petcock to carbs) and an in-line filter in each line.
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
for the vacuum, do i need to come off the petcock then T into 2 lines into the carbs?
No tee required.
Just run single vac hose from petcock vac nipple to a vac nipple on one of the carb holders.
The other carb holder nipples remain plugged (capped/sealed).
Some carb sets have a 5th vac nipple from one carb, intended for vac supply to petcock. In this event, all 4 carb holder nipples would remain plugged. Am not positive, but thinking the carbs at hand don't have such 5th vac nipple).
Petcock has ON, RES and PRI positions.
The vac to petcock allows fuel flow in ON and RES positions when the engine is running.
PRI allows fuel flow regardless of vacuum.
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
