petcock question
  • kz1k
  • Topic Author
  • You Cant Fix Stupid!
16 Sep 2010 08:29 #399097 by kz1k
petcock question was created by kz1k
hi guys. i have a petcock that has 3 outlets on it. one facing down, and 2 facing to the right. which 2 do i hook my fuel lines to? also will i need 2 fuel filters in the fuel line before the petcock?
1978 KZ1000A2
16 Sep 2010 12:28 - 16 Sep 2010 12:29 #399122 by Patton
Replied by Patton on topic petcock question
If stock petcock:
Vacuum tube attaches to highest petcock nipple;
2 lower petcock nipples are fuel outlets.
No fuel should be allowed to reach carbs without first passing through an aftermarket in-line fuel filter.
Where carbs have dual fuel intake tees, should be a separate fuel line to each tee (i.e., 2 fuel lines from petcock to carbs) and an in-line filter in each line.
Good Fortune! :)
Last edit: 16 Sep 2010 12:29 by Patton.
  • kz1k
  • Topic Author
16 Sep 2010 13:55 #399135 by kz1k
Replied by kz1k on topic petcock question
thanks patton.
1978 KZ1000A2
  • kz1k
  • Topic Author
16 Sep 2010 14:13 #399139 by kz1k
for the vacumm, do i need to come off the petcock then T into 2 lines into the carbs?
1978 KZ1000A2
16 Sep 2010 15:07 - 16 Sep 2010 15:08 #399143 by Patton
kz1k wrote:
for the vacuum, do i need to come off the petcock then T into 2 lines into the carbs?
No tee required.
Just run single vac hose from petcock vac nipple to a vac nipple on one of the carb holders.
The other carb holder nipples remain plugged (capped/sealed).
Some carb sets have a 5th vac nipple from one carb, intended for vac supply to petcock. In this event, all 4 carb holder nipples would remain plugged. Am not positive, but thinking the carbs at hand don't have such 5th vac nipple).
Petcock has ON, RES and PRI positions.
The vac to petcock allows fuel flow in ON and RES positions when the engine is running.
PRI allows fuel flow regardless of vacuum.
Good Fortune! :)
Last edit: 16 Sep 2010 15:08 by Patton.
  • kz1k
  • Topic Author
16 Sep 2010 15:22 #399145 by kz1k
heres a demo...is this correct, if not tell me whats right? the fuel line should be 3/16" is the vac line the same size hose? i got my buddy at the store right now, im sure he will buy the wrong stuff.
1978 KZ1000A2
  • kz1k
  • Topic Author
16 Sep 2010 15:30 - 16 Sep 2010 15:35 #399147 by kz1k
nevermind thats wrong....anyone have a pic of a set of these carbs with the lines labeled or something? i know...get a book...lemme look at the manual.
1978 KZ1000A2
Last edit: 16 Sep 2010 15:35 by kz1k.
  • kz1k
  • Topic Author
16 Sep 2010 15:43 #399148 by kz1k
damn i cant find it ...i wish there was a diagram
1978 KZ1000A2
16 Sep 2010 16:24 #399154 by Patton
Example (with single fuel Tee )
16 Sep 2010 16:26 #399155 by Patton
Another example (with single fuel inlet Tee)
  • kz1k
  • Topic Author
17 Sep 2010 10:38 #399331 by kz1k
am i missing the center fuel line?
1978 KZ1000A2
  • testarossa
17 Sep 2010 10:39 #399332 by testarossa
Replied by testarossa on topic petcock question
No, your carbs are a different setup. Those carbs pictured are VM28 with the accelerator pump.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
