82 CSR 1000, removed air box for pod filters
- thequam
31 Aug 2010 09:27
I have a 82 CSR 1000, I pulled the air box off of it and put individual foam pod filters on each carb, now I can hardly get it to start and when I do it runs like shit. I was curious if anyone else has done this? I'm thinking i need to put a jet kit in it, but just wanted some more input. any help would be appreciated.
Thanks
Thanks
- chance
- Life long biker/
Re: 82 CSR 1000, removed air box for pod filters
31 Aug 2010 09:33
You will have to rejet for pods I think 140 main jets and 40 pilot jets.. Do you run open or baffeled exhaust ?
- TeK9iNe
- What did you do!?!
31 Aug 2010 09:42 - 31 Aug 2010 09:47
NOOOooooooooooooooo...... :laugh:
Anyways, YES, the jetkit is an excellent source of frustration relief and headache prevention.
The BS34 CV carbs dont actually need the pilots changed out for pod filters, just a serious mixture adjustment.
There will be some flat spot/issues in the low rpm range without a steeper tapered needle, and main jet+needle position changes/experimentation are required. This also depends on the condition of each cylinder as pods makes jetting much more sensative.
I've seen requirements anywhere in between:
Pilots: 37.5 - 40
Needles: (jet kit supplied taper) #2 - #4 clip position
Mains: 135 - 170 (Oiled/non-oiled, cheap to K&N filters)
JETKIT!! YES...come with nice instructions plus tools... :laugh:
GL.
Pilots: 37.5 - 40
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 31 Aug 2010 09:47 by TeK9iNe.
- PaulsKZ1000LTD
31 Aug 2010 10:48
I put pods on my 82 Kz1000 LTD, and used a stage 3 jet kit that helped a lot. The kit came with drill bits, so I left the shop install the jets. My friends warned me that if I slipped with the drill I would have major problems. You still have to get the air mixture right and sync them.
I am wondering if I should change the timing since I also put on Vance & Hines drag pipes with an 8 inch baffle stuffed into them.
1982 KZ1000 LTD K2. Resurrected, not restored
- thequam
31 Aug 2010 10:54
baffled, it still has the stock exhaust for now
31 Aug 2010 13:00
Pods :laugh:
- otakar
31 Aug 2010 13:40 - 31 Aug 2010 13:42
This bike has the exact same setup. .420 lift cammed, 1150, 11.5:1 The carbs have new needles, 135 main jets and stock 37.5 pilots. Slides are modified. pods are EMGO 12-55754, bought at Z1E. I would put these carbs against any VM33 equipped bike of same displacement and compression.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 31 Aug 2010 13:42 by otakar.
- Motor Head
31 Aug 2010 14:14
Lots of people with Pod's and lots without. I'd save the airbox and fittings until I was real happy with the Pod's, seems there are always someone looking for 1 to go back to the box setup.
- bountyhunter
31 Aug 2010 17:08
650ed wrote:
I can't understand the attraction of pods. They not only hopelessly screw up the running but you lose the rear support for the carbs which will make the intake manifolds fail eventually. I don't get it.Pods :laugh:
- kzbobber1
31 Aug 2010 17:19
I can see the attraction to pods, the factory air box is not very attrative. Especially if you are building a chopper or bobber. My bike came with pods but I have heard so many horror stories about them that I did not want to use them. It took me a while to figure out what to do, but I ended up fabricating my own intake manifold. I will post some pics tomorrow. It works very well and looks cool too.
- hocbj23
31 Aug 2010 17:59
bountyhunter wrote:
well I can.It is an absolute beouthch to get the stock air cleaner box out if u want to work on the carbs,so lots of folks put pods on so they wont have to screw with the stock box.Me, Im old and slow and got plenty of time so removing the box is ok by me.I did stick a K and N filter in mine which is sort of a half-arze compromise I guess.Lol.bj650ed wrote:I can't understand the attraction of pods. They not only hopelessly screw up the running but you lose the rear support for the carbs which will make the intake manifolds fail eventually. I don't get it.Pods :laugh:
- otakar
31 Aug 2010 19:05
How about a massive performance increase. Pods will add quite a bit of extra umph.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
