Pods, Mac Headers,=What carb set-up
- csrjoe
My estimate is its still running a bit rich. In second gear at 5 to 6.5 rpm she bucks and spits and then smooths out.
- mark1122
- Keep twisting it
- Thank you received: 109
what jetting do u have? is it stock jetting?
was everything good before u added the pods and header?
is that all u did?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Hell, even if there slide carbs, then get a JetKit, just makes things soooo much easier.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- csrjoe
- Thank you received: 2829
- csrjoe
- csrjoe
- mark1122
- Keep twisting it
maybe u dont have stock jetting.
i would take a look and see what jets are in there . u want to know what pilot and main jet is in there, and which clip the needle clip is on(if it has 1).are they stock carbs as well? manual slides or diaframs?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- bountyhunter
- Thank you received: 337
I have a 83 csr 650 that is running good but still is sucking gas mileage at an estimated 70 miles a tank full. I believe I have a 2.8 gals. a tank. So what I like to hear what you think about the carb setting should be. She'll be in the shop on friday to set the carbs. It also has pods new, and a Mac header new.
If you put a stock airbox on it and have MAC pipes with the standard baffle, it will be very easy to jet. probably stock jets or one size rich will run perfect. An airbox is probably cheaper than a jet kit and will save a whole lot of time.
- DoubleDub
- Visitor
70 miles on a tank? I haven't ridden a 650, but on my 900 that means I'm loosing fuel somewhere other than the combustion chamber/exhaust. I'm loosing fuel out the float overflow periodically.
- mark1122
- Keep twisting it
Good point DD. my kz1200 gets 100 miles per 15 liters.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- csrjoe
