need to replace the carburetors on my '82 spectre
- reaver573
16 Jul 2010 12:15 #383125
by reaver573
Replied by reaver573 on topic need to replace the carburetors on my '82 spectre
- Thank you received: 2237
16 Jul 2010 17:12 #383175
by TexasKZ
Replied by TexasKZ on topic need to replace the carburetors on my '82 spectre
Ir you have the missing piece, a skilled welder could reattach it. Otherwise, some JB Weld, sand paper, files and patience could probable make a workable repair. As for the crud, I'd bet that a sonic cleaner would remove most or all of it. A long soak in some quality carb cleaner and some careful work with some brass brushes might work as well.
- otakar
16 Jul 2010 20:17 #383247
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic need to replace the carburetors on my '82 spectre
By the time you are done with everything on these you will be much better off to replace them with the right Mikuni BS34s and be done with it. These dual butterfly Keihins wer junk anyway.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
