- Thank you received: 43
Anyone Familiar With Keihin CR Special Carbs?
- 79MKII
- Love Them Kaws!
Also, are there any markings that will indicate the size? Most mikunis have the size right on them. Thanks!
The Kaw List:
- Old Man Rock
- Thank you received: 225
They come in sizes ranging 29mm, 31mm, 33mm, 35mm, 37mm, or 39mm so 36mm/37mm are out...
Are you measuring the inside diameter of the outlet or the outer diameter? Measure the inside...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- 79MKII
- Love Them Kaws!
The Kaw List:
- PLUMMEN
- Thank you received: 104
- 79MKII
- Love Them Kaws!
I sent an inquiry to Sudco and they told me they are 33's if ink stamped "33". Sounds simple enough, but I wanted to make sure. Now I'm kind of bummed because I already have Mikuni 33 smoothbores and wanted 35 or 37 CR's. Not sure if 33's will be enough for 1260cc with oversized valves, .425 cams and ported head??
The Kaw List:
- 79MKII
- Love Them Kaws!
My 33 smoothbores ran great before I changed to the 34 flatslides, so I just can't see spending extra money on the CR's unless they're bigger than my Mikuni's. Plus I already have lots of Mikuni parts and none for the Keihins.
The Kaw List:
- PLUMMEN
33s are more than enough for that 1260 on the street,my 1327 is running an old set of 33s smoothbores right now and it runs much better than it ever did with those damn 38sSurvey says! 33mm :laugh:
I sent an inquiry to Sudco and they told me they are 33's if stamped "33". Sounds simple enough, but I wanted to make sure. Now I'm kind of bummed because I already have Mikuni 33 smoothbores and wanted 35 or 37 CR's. Not sure if 33's will be enough for 1260cc with oversized valves, .425 cams and ported head??
- 79MKII
- Love Them Kaws!
Wow, I don't know why I didn't realize it before, but my brother has 33 smoothbores on his 1327 too. Always ran great. Maybe I'll just put the 33 mikunis back on and sell the CR's. Or are the CR's better in any way?
The Kaw List:
- Old Man Rock
Hell if I can do it anyone can....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
- will61310
- Thank you received: 6
...1980 LTD 1000...
- jeffasaki
- Thank you received: 44
Cheers.Jeff
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
