- Thank you received: 391
No throttle cable!! HELP!I
- Motor Head
24 Jun 2010 19:59 #378064
by Motor Head
Replied by Motor Head on topic No throttle cable!! HELP!I
Did you look at the second one, looked like your picture, with the curved end. Says 3 available.
- 550A2
- keep the shiny side up
- Thank you received: 1
24 Jun 2010 22:48 #378089
by 550A2
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
Replied by 550A2 on topic No throttle cable!! HELP!I
i wouldnt think the curve should be that big of a deal...
you just want a cable with the same ends, same length of actual cable, and similar length of housing. give or take about a 1/2 - 1 inch....
Id take the cable in to a place that sells em, and compair some.
- djturnz
- Thank you received: 5
25 Jun 2010 04:18 #378101
by djturnz
1982 KZ750 (4) LTD
Replied by djturnz on topic No throttle cable!! HELP!I
If it's that much of a specialty item, buy the parts and make your own cable. Hell, make 3 and sell 2 of them.
1982 KZ750 (4) LTD
- Thank you received: 2098
25 Jun 2010 10:02 - 25 Jun 2010 10:24 #378162
by Patton
Replied by Patton on topic No throttle cable!! HELP!I
djturnz wrote:
Yep. Existing sheath and related parts likely remain serviceable, with only the inner braided cable being frayed and unusable.
Just purchase a length of braided cable and some ferrules. (Each cable requires two ferrules, being four ferrules for two cables).
Attach one ferrule. Solder or braze. Don't melt the ferrule.
Insert inner braided cable through sheath.
Insert through second ferrule.
Carefully measure and cut to allow for exposed length needed plus enough to spread for soldering into ferrule.
After soldering, may carefully grind smooth at ferrule to permit fitment into throttle assembly and at carb belcrank.
Repeat for the other throttle cable.
Braided inner cable and ferrules are cheap enough. If screw up, just do another. Practice makes perfect.
Click here > www.dansmc.com/cables.htm
And here > www.dansmc.com/solder_cable.htm
...make your own cable....
Last edit: 25 Jun 2010 10:24 by Patton.
