No throttle cable!! HELP!I
- roysclockgun
Can anyone supply the needed cable, or point me in the right direction?
Steven
- Thank you received: 2098
MotionPro offers custom cables in almost any length. Just need length of sheath and amount of exposed inner cable.
Has a cable luber been tried? Or the over-night funnel drip method?
Sometimes the throttle grip mechanism gets crunchy, and needs cleaning and re-lubing inside where the cables attach.
Usually no lube is needed in this area. Just a clean, grit-free, fitment.
Some of these are unbelievably encrusted.
Another thing to check is to assure the end of the rubber handlebar grip isn't rubbing against the end of the handlebar.
- roysclockgun
The cable still binds and we believe that this is caused by fraying, inside the cable casing.
Since it appears that the 1982 style cable was only used for one year, no one has a replacement cable for sale at any price.
I sent for and received two cables that sellers promised would work, but neither had ends that mated up to my bike.
We are going to the motorcycle salvage yard to try to fine an entire throttle unit that will work on my bike, to include the handle bar grip unit and cable. We will attempt to swap out the whole thing. Any recommendations on which models may have a unit that will work on my bike?
Best,
Steven
- djturnz
- Thank you received: 5
- Motor Head
- Thank you received: 391
Which bike you got and have you called Z1 for availability of Kaw #'s above?
Here is a link to Z1, Motion Pro Cable for E3,
www.z1enterprises.com/detail.aspx?ID=279
- GPz550D1
- Thank you received: 22
54012-1058, and 54012-1114 are 2 cables shown for a 82 KZ750 E2/E3 model. Is one of those models yours? There is also an H3 LTD, and R-1 GPZ, M1 CSR.
Those Kawasaki part numbers are both available on Ebay, if you are interested.
1981 KZ550-D1
- roysclockgun
I have been in contact with the Z people and they tell me that the cable is unique to that year of 1982 and that they do not have the cable to sell.
Steven
- Motor Head
- roysclockgun
s101.photobucket.com/albums/m78/royscloc...current=IMG_4455.jpg
The throttle cable on my KZ750E2 is a single cable. See photos. I sent the same photos to Z and they said that they did not have the cable and could not get it.
Steven
- Motor Head
Or maybe its this one
cgi.ebay.com/ebaymotors/THROTTLE-CABLE-K...&hash=item563d8dc786
Judging from your photo's, this should be it. Score it fast before some one else.
- roysclockgun
What I need to do, is to find a wrecked 1982 KZ750E2 and buy the cable off of it. Or, get an entire handlebar grip unit, with cable, that will work on my bike and swap out the whole thing. I can save the old parts, just in case I find original type parts later on.
Steven
