- Thank you received: 2098
Name that carburetor
Another view
For whoever might need a new 17mm hex head,
Click > 17mm Hex Head at Z1E
Such as in case of loss or damaged threads.
May also use to drill and add a nipple thereby creating a tool for using incident to clear tube testing of fuel level in float bowl.
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Going by your user name, I suppose the bike is a KZ650 of some unknown year. Often times, mentioning the particular bike is helpful. Anyway, most of the 650s have VM24 carburetors. Some of them have an accelerator pump which is located on the bottom of the #2 carb. From the looks of your drain screws, yours are a 70s variety.
PS: if they're VM24s, the engine side opening probably measures ~26mm. The 24mm measurement is inside the carb bore near the throttle slides.
Get the jets at Z1Enterprises.com. If you're unsure, contact them.
Z1- Mikuni Large Round Main Jet #115
Pilot Jet VM22/210 - #17.5
Z1 - Sudco Carburetor Tuning Guide ~$11
Excellent advice.
Kawickrice wrote:
Dude don't confuse yourself, what you have is a standard for the 650 set of VM24 carbs. Mikuni has what is called Large main jets and small main jets. Yours happens to have the "large" mains. Your mains fit a wide wide variety of Mikuni carbs. Just order the large ones in whatever size you need. Good luck.
The main jets are K&L which should be fine. I don't know what the pilot jets are - the part number is preceded by a TU. K&L parts are usually denoted by KL in the number. Also, I don't know if those sizes are correct for your application.
More excellent advice!
If the model year is unknown, it may sometimes be found in a VIN sticker located on right side of steering head. Or on the title or other papers associated with the bike or license tag.
The VIN or engine serial number could help, and might also be tracked through Zedder.com.
With the year model known, the carb parts diagram at kawasaki.com often provides jet sizes and alternate sizes. Babbits.com may provide similar info.
To get started at kawasaki.com, click > kawasaki.com/DefaultFrame.aspx?strConten.../VICHOOSEVEHICLE.ASP
- btkz650
Thanks again. You guys are a huuugggge help.
...think I need to order 115 main jets and 17.5 pilot jets....
Others will have more experience and better advice, but my guess under the circumstances would be that 115 mains and 17.5 pilots would be as good as any to start with.
If the existing jets appear serviceable and are anywhere close in size (sometimes difficult to read even with strong light and magnification), would consider test running them and see how the engine performs. Be careful not to hold wide open throttle for very long, especially if bike seems to be holding back from lack of fuel. If so, add a little choke for effect. If choke improves pull, main jets are likely too small. If engine burbles and worsens with added choke, main jets are likely too large.
In any event, with pods and headers to open air, carb tuning will be a tough row to hoe.
- tinlizzie37
Bob KZ 650 E1, En 450
- btkz650
I think I can get the jets from a local Yamaha dealer by me. They said to just bring in one of mine so they could match up the type.
tinlizzie37 wrote:
Hi BT, Z Enterprise has the jets you need plus the gaskets. Go to Harbor Freight and get their metric nitril o'ring set, they have all the o'rings you will need for replacing the old ones. This is if you have a KZ 650 with the VM 24's. I got my jets and gaskets there. Good luck. Bob
- PLUMMEN
- Thank you received: 104
- btkz650
- Kawickrice
If you go to the local Yamaha dealer dont let them gouge you on the price. Anything over 4 bucks a jet is to high. I paid 2.60 ea for the pilots and 2.40 for the mains if I recall correctly. That was from Z1E. My local shop wanted almost 5 bucks apiece for the same jet.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
