Name that carburetor
- MentalMike
- God Bless America!
24mm mikuni smoothies
yep mikuni VM 24SS
Got those on my 650.
I swear to God, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity.
1976 Kawasaki KZ900
1978 Kawasaki KZ1000A
1978 Kawasaki KZ650 C
1984 Kawasaki ZN1100 LTD
1985 Kawasaki ZX900A2 GPZ (2)
1985 Kawasaki ZL900 Eliminator
2013 Kawasaki C14 Concours
- btkz650
- Old Man Rock
- Thank you received: 225
www.sudco.com/mikunijets.html
Measure the intake openings... VM's... 24mm or 26mm?
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- btkz650
Sorry again for all the dumb questions, but I'm pretty new to this stuff. I've only gone as far as cleaning carbs and replacing seals. Never messed with re-jetting, timing, or compression issues yet, but I'm learning a lot from you guys.
Old Man Rock wrote:
Sudco is a good source, may not have all though on older Mikuni carbs...
OMR
- H1Vindicator
- Thank you received: 51
- H1Vindicator
- Thank you received: 2098
Both are manual slide carbs.
And both incorporate a jet block over which the slide moves up and down.
Both have a 17mm hex drain screw on bottom of float bowls without overflow drain nipple (no overflow circuit).
Neither have separate drain screws, except some very early 29mm smoothbore models have a side located drain screw on the float bowl without the 17mm hex nut.
Read the details and see pics by clicking here > www.z1enterprises.com/reference/z1-carb-guide.aspx
If there are other size smoothbores out there somewhere, such as 24mm or 26mm or 28mm, I don't know about them.
- btkz650
Patton wrote:
Mikuni Smoothbores or Smoothies were produced in 29mm and 33mm sizes.
- btkz650
- Old Man Rock
Yours has the float bowl nipple thus not 29mm smooth bores...
Your miss understanding what Patton provided... He was giving you the Smooth Bore definition and the differences on a "Smoothie thus 29mm smooth bore carb"... The 26mm and 29mm look similar but with some external variances and obviously internal as well.
Measure the carb opening, you'll most likely measure 24mm, possibly 26mm...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- H1Vindicator
