- Thank you received: 19
Interesting carb intake fabrication
- porchev914
That one is better but the outside carbs still have longer intake paths.
BTW, what the hell is that? A PTO? :laugh:
Naw, It must be the transfer case to engage the front wheel for full time 2 wheel drive :woohoo:
FRANKEN Z!
- sabell
'78 KZ1000A2
'79 650SR
- porchev914
A gerbil powered centrifugal blower...now thats GENIUS. Totally changes the dynamics of this!Ok I give...It's the super secret gerbil drive I've been working on.
FRANKEN Z!
- Thank you received: 2098
- Thank you received: 2829
Naw, It must be the transfer case to engage the front wheel for full time 2 wheel drive :woohoo:[/quote]
That model didn't have 2 wheel drive. The belt you see in the pic is used to run the power steering pump. Ed
- JMKZHI
- Thank you received: 48
Or did you just glue up some 90s & Tees, cut a couple of holes w a hole saw, then glue in some pvc pipe or something?
- JMKZHI
If only the guy painted the frame black & everything else black or silver.... too bad he chose that blue. He ruined what would've been a nice resto.H1Vindicator wrote:
i used to stop by there untill they changed forum host....He posted photos of the bike in this topic... 79 KZ1000 95% complete . Too bad he painted the frame & whatnot that hideous blue - uuuglyyy. He said the bike runs "amazingly well", but the carbs need to be "tweaked".
he had a lot of good intentions, but that paint job was butt ugly....that was one funky color.....:S
- Old Man Rock
- Thank you received: 225
Modified Mod Coil Mod? :blink:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Kraz1
- sabell
It's a combo of 90's on the 2 outboards and 4-way T's for the 2 inboards. They had to be trimmed to get proper center to center measurements. Attached to carbs with rubber couplers that I cut in half so I could get 2 carb mounts out of 1 coupler. Pvc is Schedule 40 1 1/2in. 54mm Emgo pods on the backside of the 4-way t's. Less then $30 including pods.What pvc fittings are the pods hooked to on the FJ600?
'78 KZ1000A2
'79 650SR
- PLUMMEN
- Thank you received: 104
thats nice work!www.cyclemadness.com/cmforum/index.php?t...=680.msg4932#msg4932
