- Thank you received: 2
If it aint broke, DON'T FRACKIN FIX IT!!!!!!!!!!
- Galactica
14 Apr 2010 17:35 #360688
by Galactica
77KZ1000
76 KZ900
If it aint broke, DON'T FRACKIN FIX IT!!!!!!!!!! was created by Galactica
I have a 76 kz900 A4. All stock except for 4 into 2 MAC slip-ons. Got it a year or so ago. Finally got it running really good this spring.
I've been reading posts about how to clean fuel system, crank case, and combustion chambers.
-So I ran a tank of fuel with Sea Foam. No problem.
-Then last night I put some Rislone combustion chamber cleaner in and left it over night.
-This morning I went out, pulled out the plugs again and kicked it over a few times to purge. Plugs back in, hit the starter, couple of turns and BAM! Huge back fire. Try it again. BAM! Try it again it fires up, seems fine.
-Put 1/2 can Sea foam in the crank case. Go for a 30 Km (20 mile) run. Doesn't feel quite right, but not bad.
-Get home, change oil. Start it up. Sounds off. Pull it out of the garage. Notice a miss right away. I go for a short spin. Miss is still there.
-Spray water on head pipes. #2 is cold. Check plugs, #2 is black and sort of wet. Check compression, not great, but no change from before. Check spark, OK. Check timing and points, spot on. Change coil, no difference.
WTF!! HELP ME PLEASE!! I was planning to ride it to the Vintage Bike Show and swap meet on Sunday. I don't really want to ride it on three cylinders.
77KZ1000
76 KZ900
- Old Man Rock
- Thank you received: 225
14 Apr 2010 17:41 - 14 Apr 2010 17:41 #360691
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic If it aint broke, DON'T FRACKIN FIX IT!!!!!!!!!!
Have you gone through all the gas in the tank?
If not run it (personally I'd dump it) and get some fresh gas and a new set of plugs in there...
"Finally got it running really good this spring."... And you did this gas treatment why when it was running good.... :whistle: I know, I know...
Also check your carb air filters to see if they're soaked with that shit...
In line fuel filter clean?
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 14 Apr 2010 17:41 by Old Man Rock.
- Galactica
14 Apr 2010 17:55 #360697
by Galactica
77KZ1000
76 KZ900
Replied by Galactica on topic If it aint broke, DON'T FRACKIN FIX IT!!!!!!!!!
Air filter is good. New plugs also when I noticed the miss. Float levels are all good. Have good quality in line fuel filters.
I know, I know. It was running fine. I shouldn't have touched it. Just wanted it to be as perfect as possible. Could the combustion chamber cleaner have dislodged some crap that is stuck in the valve? The tops of the pistons are really clean now. Or is it just coincidence and something is stuck in the pilot system of #2 carb. It's hard to tell, but it seems to run fine wide open.
77KZ1000
76 KZ900
- Old Man Rock
14 Apr 2010 18:05 #360699
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Definitely possible some fine ass crap got into the jets and such...
If stuck in a valve... hmmm... One way to check would be compression and leak down testing I guess...
I 'd stick with your carb theory myself...
Sorry to hear about this but as Plummen and Larry have informed me numerous times (actually screamed "What the hell you do that for dumbass") leave it the hell alone for you have it dialed in already... Now go ride the balls off that thing and quit dickin with it....
Damn, my mentors can be a tough crowd at times... :laugh:
:laugh: :laugh: :laugh:
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- jeffasaki
- Thank you received: 44
14 Apr 2010 18:14 #360701
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Replied by jeffasaki on topic If it aint broke, DON'T FRACKIN FIX IT!!!!!!!!!!
FRACKING BATTLE FRACKIN STAR GALFRACKINACTICA FRACKIN LIVES FRACKIN ON.DONT FRACK A FRACKIN ROUND.
HAHAHAHAHAHA:woohoo: :woohoo: :woohoo:
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Galactica
14 Apr 2010 18:57 #360716
by Galactica
77KZ1000
76 KZ900
Can I tell if it's a problem with the pilot system buy running at high rpms for a while, then hit the kill switch and pull in the clutch? Then pull over and check the plugs?
77KZ1000
76 KZ900
- trianglelaguna
- Thank you received: 235
14 Apr 2010 19:11 #360723
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic If it aint broke, DON'T FRACKIN FIX IT!!!!!!!!!!
carb junk.....do you run a fuel filter...strange that it only one carb....pull the carbs...and inspect each piece of just that bowls jets ...passages..i think somehting may have got wedged in a jet...
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
14 Apr 2010 19:11 #360724
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
did i miss it...do you have sparkles on that plug/wire....
1976 KZ900
2003 ZX12R
2007 FZ1000
- Galactica
14 Apr 2010 19:36 #360737
by Galactica
77KZ1000
76 KZ900
Have good spark. Switched #2 & #3 wires. Both 2& 3 pipes were cold. Then I switched in a new used coil, checked sparks. All good. #2 pipe still cold and plug black and wet.
Have good gas filters.
77KZ1000
76 KZ900
- trianglelaguna
14 Apr 2010 19:59 #360741
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
so the compression is close like before on that cyl...you got sparkles.....you got a good plug....wet plug..ie..gas getting into that jug..:S ..try a b7es in that cylinder for a few miles... a new one...let it sit over night with all four of the plugs out and gas off and vented area....then try three b8's and a b7 in the 2 cyl......dunno.....i can reason o.k but i'm no tech guy...if all is correct as you've checked it should at least be firing...2nd scenerio ...check the valve clearances especialy on number #2...good luck....it'll solve and you'll be riding to the show..98% percent of the time these old girls get running again imo...
1976 KZ900
2003 ZX12R
2007 FZ1000
- jeffasaki
14 Apr 2010 20:06 #360742
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Try turning the pilot air scew out a full turn on the cylinder thats running rich.take it for a run let it get nice and hot then check the plug.I think that youll find each cylinder has got to be tuned to its proper air/fuel ratio.these old air cooled engines have inconsistent cylinder temperatures and each cylinder has to be tuned with the carb thats giving it gas.
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- sft1662
15 Apr 2010 12:15 #360860
by sft1662
1978 KZ650 B2A
Replied by sft1662 on topic If it aint broke, DON'T FRACKIN FIX IT!!!!!!!!!
Go for a short ride of a couple miles, check and see if that header is still cold or if it heated up some. If it did, probably a clog in the choke circuit (hole in the bottom of your float bowl). Just figured out thats why my #2 was cold...Header would be ice cold when idling or revving but after a ride there was evidence that it was sometimes firing (warm, plug changed a little). The plug told me nothing - it would be wet sometimes and dry others but it all went away when I cleared the choke circuit :whistle: Good luck... worth a try at least
1978 KZ650 B2A
