HELP!!!!!!!!! carburator desaperation times
- runningtat
13 Apr 2010 14:01 #360407
by runningtat
Replied by runningtat on topic HELP!!!!!!!!! carburator desaperation times
hi
thanks for the response
i have a stupid question. when looking down at the with the bowl facing up and off.the float's most rounded side as opposed to the indented side is pointing up. is this correct.
runningtat
1977 kz650
runningtat
1977 kz650
- Thank you received: 2098
13 Apr 2010 14:19 - 13 Apr 2010 14:27 #360409
by Patton
Replied by Patton on topic HELP!!!!!!!!! carburator desaperation times
runningtat wrote:
From the diagram, the float seems to be installed with the float indentations on the top when carbs are in normal operating position.
Another matter is that each float needle should always remain with its same seat. Getting the needle mixed up and reinstalled with a different seat invites fuel leakage.
...when looking down at the with the bowl facing up and off.the float's most rounded side as opposed to the indented side is pointing up. is this correct....
Last edit: 13 Apr 2010 14:27 by Patton.
- OKC_Kent
13 Apr 2010 14:24 #360411
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic HELP!!!!!!!!! carburator desaperation times
Just like pattons picture above.
So if the carb is off the bike and upside down in your hand, then the round part of the float is facing up.
Oklahoma City, OK
13 Apr 2010 14:30 #360415
by Patton
- Motor Head
- Thank you received: 391
13 Apr 2010 18:00 #360455
by Motor Head
Replied by Motor Head on topic HELP!!!!!!!!! carburator desaperation times
If you look at the floats you should see the tang that the needle pushes against, then another Tang which is the float drop tang. This tang will let the float hang down so fuel can enter with the Carb upright. So this Tang should hit the Carb Body at the float tower, that's were the pivot pin slides in. Use a book and set the float level on the bench to get it in the correct ballpark, I would buy some kits and do them right or you'll most likely be pulling them off again for a restricted low speed circuit.
- JR
- Thank you received: 449
13 Apr 2010 18:45 #360485
by JR
Replied by JR on topic HELP!!!!!!!!! carburator desaperation times
In addition to all the great advice above .... one other suggestion.
I had similar problem this spring. Took the carbs off last November, cleaned them out and replaced the float needles and when I put them back on the bike a month ago I had gas coming out 2 of the 4 overflows. To make a very long and frustrating story short my needle seats were dirty. They cleaned up well with some Brasso on a Q tip and wallah ! no more leaks
- bill_wilcox100
- Thank you received: 5
14 Apr 2010 06:26 #360568
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic HELP!!!!!!!!! carburator desaperation times
JR wrote:
Good stuff JR. That's a new one for me.
Best of success,
Bill
... needle seats were dirty. They cleaned up well with some Brasso on a Q tip and wallah ! no more leaks...
Best of success,
Bill
Upgrades:
Montreal, Canada
