HELP!!!!!!!!! carburator desaperation times
13 Apr 2010 06:37 - 13 Apr 2010 13:55 #360312 by runningtat
I took my carbs off to clean them after the winter ...the bike would not start...put them back together and now gas overflow in all 4 carbs....the just will not hold gas in...took them apart a second time...clean them out woth compressed air and carefully pit them back ..and boom ..the same..gas overflow from the drains...so i did it a third time..and the same...what am i doing wrong.. i put a new "T" gas line in ..all i did different...does the needle seat have an "O" ring that i am missing. Does the needle sit snug.....When looking at the bowl with the cover off and assembled, when held upright as if on the bike the float is down as it should be while the needle slides out to contact the flot. I have not bent or touched the adjustments of the float....WHAT AM I MISSING.......HELP
1977 kz650
nova scotia, canada
Last edit: 13 Apr 2010 13:55 by runningtat.
  • Skyman
13 Apr 2010 09:09 #360343 by Skyman
Replied by Skyman on topic HELP!!!!!!!!! carburator desaperation times
Not trying to be a smart ass, but for starters, the bike model/yr and carb type.
Knowing this info will make it easier to give useful advice.
B)
West Linn, OR
13 Apr 2010 09:19 #360344 by Bad Dad
Replied by Bad Dad on topic HELP!!!!!!!!! carburator desaperation times
ALL four carbs? They all function independantly, so it's got to be the floats... could they have been put on upside down?
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
13 Apr 2010 09:21 #360346 by runningtat
Replied by runningtat on topic HELP!!!!!!!!! carburator desaperation times
it is a kawasaki (obviously) 1977 kz650 the inscription on the carb is MC MIKUNI KOGYO.....
  • Skyman
13 Apr 2010 09:31 #360348 by Skyman
But let me try to give some general advice.
The valve seat doesn't have an o-ring. They usually do have a washer that seals the outside of the seat to the carb body, and these are easily replaced if needed. It is more likely, however, that the needle tip will wear out first. You should remove the valve needle and inspect the tip. If it is worn, as shown below, it should be replaced.
Depending on the type of carbs you have, you should have no problem buying new needles, and possibly seats.
It is also possible that there is still a spec of dirt/contaminant lodged in the valve opening which is keeping the needle from seating fully. Make sure this is completely clear.
Good luck.
West Linn, OR
  • Skyman
13 Apr 2010 09:34 #360349 by Skyman
I think that bike came with VM24 carbs, which I'm not familiar with. We've got a lot of 650 guys here, though, and I'm sure one of them will chime in.
West Linn, OR
  • Skyman
13 Apr 2010 09:38 #360351 by Skyman
Or...
You could always get some carb rebuild kits and replace all the o-rings, gaskets, needles, and seats at once, just to be sure. ;)
www.z1enterprises.com/detail.aspx?ID=42
West Linn, OR
  • TeK9iNe
  • What did you do!?!
13 Apr 2010 09:39 #360352 by TeK9iNe
Replied by TeK9iNe on topic HELP!!!!!!!!! carburator desaperation times
Are you sure all the drain screws are closed?
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
13 Apr 2010 11:09 - 13 Apr 2010 11:28 #360362 by bill_wilcox100
Replied by bill_wilcox100 on topic HELP!!!!!!!!! carburator desaperation times
runningtat wrote:
...gas overflow from the drains...
As has already been suggested, if the Needle Valve is not shutting completely then fuel will fill and overflow the Float Bowl and the excess fuel will flow out the brass Overflow Pipe and down the black rubber Overflow Hose to the ground below.
Four causes come quickly to mind:
- 1) Flooded Floats... all four at the time is not likely.
- 2) Deteriorated Needle Seat condition... all four at the same time is possible I guess.
- 3) Fuel Service Level adjustment is too high... is a very popular fault cause.
- 4) Fuel Tank debris and junk preventing the Needle Valve Seat from sealing properly... is another popular fault cause.
See the diagram below for cutaway view of my 1977 KZ650-B1 carbs:
Best of success, :)
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 13 Apr 2010 11:28 by bill_wilcox100.
13 Apr 2010 11:12 - 13 Apr 2010 11:25 #360363 by bill_wilcox100
Don't know how to get two pictures on the same post...
- You will need to get a Service Manual for your bike.
- You will need to do the Fuel Service Level adjustment using the Clear Tube Method only!
See below for a diagram of the Fuel Service Level adjustment:
Best of success, :)
Bill
Upgrades:
Montreal, Canada
Last edit: 13 Apr 2010 11:25 by bill_wilcox100.
13 Apr 2010 11:16 - 13 Apr 2010 11:23 #360364 by bill_wilcox100
And finally, you will need to:
- Empty and clean your Fuel Tank.
- Clean and or replace your Petcock's Fuel Filter.
- Add or replace an Inline Fuel Filter (See below):
Best of success, :)
Bill
PS
You will want to add your Year, Model and Location to your signature to get the very best responses... and yes it's considered very friendly.
Bill
Upgrades:
Montreal, Canada
Last edit: 13 Apr 2010 11:23 by bill_wilcox100.
13 Apr 2010 13:02 #360391 by Patton
Replied by Patton on topic HELP!!!!!!!!! carburator desaperation times
If in doubt about whether floats might be installed upside down, this diagram from kawasaki.com shows the float cut-a-ways on the "top."
But can't vouch for accuracy of the drawing. :unsure:
Good Fortune! :)
[Click on image to enhance view.]
