- Thank you received: 10
Got it started but i have some questions...
- Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Thank you received: 2098
...After it starts, you can take your hand away and let it run on half chock. It won't run without chock or else it will die. Well, It runs, but its runs really crappy. It revvs up to like 5000 RPM on its own and then drops down to 2000 then revvs back up to 5000 again. It won't stay at a steady idle and it does the revving all by itself. As soon as you give it alittle throttle, any at all, it dies. whats the issue sound like to you guys?...whats wrong with it?....
Would suspect dirty carb pilot circuits plus air leaks.
- anarki650
- Thank you received: 5
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Thank you received: 2829
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- timebomb33
I THINK MY POWERBAND BROKE
- bountyhunter
- Thank you received: 337
A giant ass vacuum leak.After it starts, you can take your hand away and let it run on half chock. It won't run without chock or else it will die. ///It revvs up to like 5000 RPM on its own and then drops down to 2000 then revvs back up to 5000 again. It won't stay at a steady idle and it does the revving all by itself. As soon as you give it alittle throttle, any at all, it dies. whats the issue sound like to you guys?
- Grantl
- KZRider is Da Bomb!!!
- Thank you received: 4
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
- TeK9iNe
- What did you do!?!
just to fire it up and run it you don't need the filters on
? you mean if its jetted for pods right?
No bike I've had is rich enough to run stock jets/off choke at idle without the airbox and filter installed.
Everything from air filter to exhaust end must be air tight!
Check valve clearances.
Clean, filtered fuel.
Check timing.
New plugs.
Check fuel/float height.
Mixture screws to 1.5 turns from lightly seated.
Change oil.
Charge battery.
etc.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
that was another thing with the mixture screws... They are loose. They have those springs in there to keep them tight but they just don't seem right....
Don't know if applicable in this case, but some pilot adjustment screws are supposed to have an o-ring.
Just guessing that possibly a missing o-ring could cause the screw to be loose.
