Spitting noises - blow back
  • Gorham
  • Gorham's Avatar Topic Author
10 Apr 2010 18:41
#359803
I got my 80 KZ650 E1 running again, but i'm having some issues with the carbs still. When i'm riding i get this spitting sound coming from my carbs. it sounds like i'm popping popcorn or something when i'm accelerating or deccelerating. i think it's blowing gas back but i can't figure out from where. what would cause this?
it's also dragging ass when you try to really open up the throttle.
i'm sure i'll have to take the carbs back off to do something, but what should i be looking for?
  • Kawickrice
  • Kawickrice's Avatar
Re: Spitting noises - blow back
10 Apr 2010 18:45
#359805
Get a couple cans of carb cleaner and spray all the little passages, pull the jets and make sure everything is clean. There are not many parts in there just make sure every thing is clean. Also clean the tank and replace the fuel filter or you will suck trash into your clean carbs and have to pull them again.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Gorham
10 Apr 2010 18:49
#359808
I'm all for it.
What's causing this though? Is it an air problem or a fuel problem?
Spark plugs misfiring?
  • Motor Head
  • Motor Head's Avatar
10 Apr 2010 18:51
#359811
Have you checked your compression? It may be a tight intake valve, or you could have a worn exhaust cam lobe. Do a compression test and clean the carbs as suggested with a sync as well. Make sure of no vacuum leaks. Its also possible that your Ignition is letting you down, check your plugs while you got them out, make sure you've got excellent spark.
  • Kawickrice
10 Apr 2010 18:55
#359813
Sounds like the carbs to me. Points will do this to when the adjustment goes away. These bikes are old and trash gets in the tank and goes straight for the carbs. Have you taken the carbs off and cleaned them?
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
10 Apr 2010 18:56
#359814
Make sure that everything from air filter to exhaust end is completely air tight!
Generally, if your putting a demand on the bike (accellerating) and it bogs down, its too rich. If you have hesitation/erratic at idle, its lean. Not always, but most times...
Swap your Main Jets out for a smaller/leaner set, and see what happens. If it improves, then go leaner again. When it stops improving with a change, go back to the previous jets. Same thing for going larger jets.'
Jet it correctly. Set your mixture screws with an accurate tach or vacuum guage. Balance your carbs.
GL!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Gorham
10 Apr 2010 19:18
#359826
How do i know if there's a vacuum leak?
All my intake and air box boots look good. My bike didn't have the stock air emission cleaner so i just capped off the inlets on the valve cover and carbs.
I've pulled and cleaned the carbs at least 3 times in the past year. new accelerator pump kit, new gaskets, new float needle. I don't have leakage anywhere when shes running or not.
I do need to synch the carbs still. i did the bench synch with the wire by the book. i don't have a vacuum guage or a fuel level guage for the float height though. i just saw the homeade version of the vacuum synch though. pretty awesome. where can i get one of those float height levels that's not like $60. I searched on ebay but didn't find one. i'm sure my float heights are off. i can't get an accurate reading with the clear tube method. it's incredibly frustrating when you don't have a proper work space. (mine's my driveway and out of the back of my van for now)
10 Apr 2010 19:52
#359832
Here's how to check carb holders for vacuum leaks: Idle the bike down to the lowest RPM it will idle at; while idling - spray carb cleaner around carb holders where they mate with the cylinder head. If the bike stalls or the idle changes noticably the carb holders are not sealing properly with the cylinder head. If this is the case, replace the carb holders. They can look perfect on the outside but still have tiny cracks on the mating surface between the carb and head that allow air to be sucked in at idle. These cracks can really effect idle but generally don't effect running much when the throttle is open because the open throttle lets much more air in through the carb and less vacuum on the carb holders. Ed
10 Apr 2010 20:12
#359834
  • Kawickrice
10 Apr 2010 20:18 - 10 Apr 2010 20:28
#359837
Take some carb holders and mount them on a piece of wood and level them (the ones in the pic are level its me using the camera thats out of level) B)
I use a chalk bottle for carpenters chalk to fill the bowls with gas. Then I use the clear tube to drain it back into the bottle. Its a tedious job sometimes but it has to be done. The clear tube is on the 2nd carb.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 10 Apr 2010 20:28 by Kawickrice.
  • Gorham
29 Apr 2010 17:51
#364299
So i'm adjusting my timing, and i can't get my ohm meter (digital multimeter) to fluctuate when adjusting the points plate on the backing plate like it says in the manual. Is there a trick to this?
I tried adjusting the backing plate to get more movement but I still can't get any fluctuation on the meter.
I still have to get the timing right with the light, but that's the next step... I'd like to get the one before it done right first.
My carbs are clean as a whistle. I think this is a major problem with this blow-back.
  • timebomb33
  • timebomb33's Avatar
29 Apr 2010 18:01
#364302
if you are setting points with a meter get a cheap analog meter and watch for the needle deflection. a digital isn't precise enough to be able to watch for fluctuations. i use an analog for setting points and for checking switches for the same reasons.
I THINK MY POWERBAND BROKE
