Jets
08 Apr 2010 18:08 #359350 by 7879KZ650S
Jets was created by 7879KZ650S
I am new to motorcycles and I need to know how you figure out what jetsI need in my bike. I know I have after market exhaust, but I dont know what it is!? It is a 4 into 2. I bought a set of rebuilt carbs off ebay. The guy does great work but it has stock jets in it. I checked the old carbs but dont know if the jets in it are stock or not. It looks like they say 102.5 but I cant tell at this point with out cleaning them up more.
08 Apr 2010 18:22 #359357 by timebomb33
Replied by timebomb33 on topic Jets
how does it run with those carbs and pipe set-up.that would be my first question. if it run's decent don't worry about jetting.
I THINK MY POWERBAND BROKE
08 Apr 2010 18:35 #359363 by anarki650
Replied by anarki650 on topic Jets
If your pipes have baffles and you're running stock airbox you likely don't need to rejet and stock jetting will be perfect for you. Stock jetting is 102.5 main, 15 pilot. That's likely what in the rebuilt carbs you bought. If you have no baffles in your pipes you'll likely want to bump up a jet size or two on your main, to either 105 or 107.5. If you're running pods you'll need to go up a few more sizes on the main, plus a size on the pilot, to 17.5 pilot and probably 112.5 or 115 main (depending on if the pipe is baffled and what elevation you're at).
Hope that helps!
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
08 Apr 2010 18:42 #359365 by 7879KZ650S
Replied by 7879KZ650S on topic Jets
It's not running right. It runs OK, but I have a very slight surge when at a steady throtle
09 Apr 2010 09:20 #359474 by timebomb33
what kind of rpm is the surge happening in.
09 Apr 2010 17:23 #359583 by Nebr_Rex
Replied by Nebr_Rex on topic Jets
that would be a lean mixture
try 107.5 mains,17.5 pilots and raise the needle 1 groove
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
10 Apr 2010 05:00 #359649 by 7879KZ650S
Thanks, I knew it was lean, just wasnt sure what to do about it,as in what size jet it should have. Now, where can you purchace jets? And if I change the cam will it also affect the jetting? I have a st of Andrews #10 grind I plan on installing soon
10 Apr 2010 12:06 #359695 by anarki650
You can order the jets you need from z1eterprises.com. And yeah, I'd imagine you'll need to rejet again after cams, not sure to what point though.
09 Kawasaki ER6n
Omaha NE
10 Apr 2010 15:04 #359718 by 7879KZ650S
At that point would it be a matter of experimenting? or might there a formula for figuring this out. Or just keep asking questions til I find some one who has done one simular?
  • TeK9iNe
  • What did you do!?!
10 Apr 2010 19:46 - 10 Apr 2010 19:48 #359831 by TeK9iNe
Replied by TeK9iNe on topic Jets
Whoa! If its lean at one point in the throttle circuit, don't change the entire fuel map.
Start with one circuit at a time. Fuel delivery/circuit/jet used is entirely dependant on throttle position.
If the bike is rideable, start by tuning the Main Jets.
Get the bike up to 4th gear early, then full throttle it till a couple thousand before redline.
Do it a couple times to really know how it "feels". then change out your jets for a leaner set (smaller number).
If the bike improves, continue to install smaller jets till there is no mor improvement. Then go back one set of jets.
It works the same in reverse... go larger jets if it improves, then back off one set when no more improvement.
Next, do the needle clip position. Same process, except at half throttle. Move clip up or down, and feel for improvement. Keep position that feels best.
Next, is Pilot Jets. Adjust Mixture screws to stock positions, approx 1.5 turns out form lightly seated.
Same process with selecting jets, except you choose the one that gives you the best launch/off idle snap up to 4000rpm, from stand still. Only using about 1/8th to 1/4 throttle!
Then adjust your mixture screws with a really good tach or vacuum guage.
YES, its going to take some time and cash, and many jets to get it right. When you do, your bike will be a rocket!
Make sure float/fuel levels are correct and NO AIR LEAKS.
Good Luck!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 10 Apr 2010 19:48 by TeK9iNe.
12 Apr 2010 12:36 #360147 by 7879KZ650S
LOL YEah, its a lot cheaper and easier rejetting a holley 4 barrel, maybe I'll design a manifold to use one of them!LOL
12 Apr 2010 12:54 #360151 by Bad Dad
Replied by Bad Dad on topic Jets
It cost's nothing to adjust the needle position (just time), and I think that's where your problem is... :unsure:
It'll be worth it... trust me! :)
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
