petcock
- csrjoe
- Russ Jackson
- Thank you received: 1
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
- mtne87
- csrjoe
- csrjoe
- Old Man Rock
- Thank you received: 225
Disconnect the fuel line off the carb, and find out which arm orientation is what...
You'll also want to insure the petcock does indeed shut off...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- csrjoe
- JMKZHI
- Thank you received: 48
Howdy. Do you have the Owner's Manual for the bike?at 9 o'clock it say pri and at 3 its res, their are 2 rubber lines coming off the petcock, there's one thing though when it had a little gas in her the petcock was in the same position up and down no gas leak anywhere. the pervious owner said if i put it on any other setting gas would come out. thanks for help
Just in case... it may be in the pull-down compartment on the underside of the seat.
Referencing the OM from the 83 650-CSR...
The stock petcock is RES-PRI-ON...
RES is to the left (9pm). PRI is at the 6 o'clock position. ON is to the right (3pm).
So, maybe you don't have the stock petcock or the bike isn't an 83 model.
It may be time to rebuild the petcock or replace it.
FYI: a new 2005 KZ1000-Police unit should bolt-on to your tank.
(info from using the cross-reference & supersession data at Kawasaki.com).
Z1Enterprises.com may have a kit for it: either oem or K&L. If you don't see either/or, or you'd like the a new one from the Police bike, contact them w your needs
- H1Vindicator
- Thank you received: 53
- csrjoe
- JMKZHI
- csrjoe
actually a better flashlight convirm's your comment thanksIt may be time to rebuild the petcock or replace it.
