Dropping stock air box
- likes2gofast2009
I have decided to keep the stock air box and am currently looking for a cone filter that will fit the back of the box with the silencer removed. The lines going into the silencer are just vents.
I am going to try out a 112.5 main because after running the bike with the straight pipe and no silencer it is running really lean (plugs are white and low end is really choppy).
Bike sounds awesome without the baffle though, thats a plus
1980 KZ1000 LTD "Brandi"
4-1 Kerker
Dyna Coils
More to come this winter!
- Thank you received: 2098
Update
I have decided to keep the stock air box and am currently looking for a cone filter that will fit the back of the box with the silencer removed. The lines going into the silencer are just vents....
cone filter that will fit the back of the box with the silencer removed --- does this mean attaching a filter to rear of airbox after removing the silencer, which would be adding another filter in addition to the regular filter inside the airbox?
[Click on image to enhance view.]
- likes2gofast2009
likes2gofast2009 wrote:
Update
I wouldn't leave the filter in the box... It's just cheaper to buy a cone filter than the stock one from a dealership.
4-1 Kerker
Dyna Coils
Click > Z1E oem style
Click > Z1E K&N
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- larrycavan
- Visitor
Remove them and go with the single K&N filter on the air box opening in the rear. Yank the stock filter and put the cover back on the top of the box.
You can get a huge variety of K&N filters. Certainly there's one that will fit your specific application.
- Bluemeanie
- DoubleDub
- Visitor
The only part that still sucks is removing the carbs and reinstalling. Hopefully I'm just about done doing that....
- likes2gofast2009
Larry- Thanks for the input I may give that a try as well.
Bluemeanie- Having similar problems as the ones stated in the article, thanks for sharing. Bike is really choppy until about 3-3500rpms, but rips like a bat outa hell once up in the higher rpms.
When I pulled the carbs I discovered that the bike already has 115 mains in there, I thought it still had the 102.5 mains that came stock. Since it is running pretty lean I'm going to try out a 125 main and see how they do.
Current mods: Dyna coils, kerker 4-1 with gutted mac pipe, and 115 mains. Again the bike is an '80 KZ1000 LTD B4
Any other tips?
4-1 Kerker
Dyna Coils
- DoubleDub
- Visitor
