- Thank you received: 2098
Done Everything, Still Has Hanging Idle
Perhaps pilot mixture is too lean (resulting from screw being turned out too far counter-clockwise).
In line with otakar's suggestion, would re-set all 4 pilot air screws at say 1.0 turn out from lightly seated. Then test run for effect on idle peformance.
Then re-tune each individual pilot screw in usual manner for best low steady idle.
This screw regulates volume of air allowed into the pilot mixture. Turning in clockwise reduces air to enrich mixture. Turning out counter-clockwise allows more air for a leaner mixture.
Good Luck!
- tinlizzie37
- Thank you received: 1
Bob KZ 650 E1, En 450
- redwood
- 81 650 CSR
I drilled out the caps, adjusted the pilot/fuel screws already.
The o-rings we're talking about part of the enrichener circuit...I don't know if those were replaced. Are we talking about part 670 on the image, or the plunger caps as well?
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
...I drilled out the caps, adjusted the pilot/fuel screws already. The o-rings we're talking about part of the enrichener circuit...I don't know if those were replaced. Are we talking about part 670 on the image, or the plunger caps as well?....
Fwiw, kawasaki.com shows 0-ring only on version without plug (Canadian). And no 0-ring on version with plug (U.S.).
Perhaps the plug must remain to seal against outside air intrusion where there's no 0-ring (U.S.).
Just speculating.
Here's the diagram from kawasaki.com.
Part #11009D is the 0-ring.
Good Luck!
[Click on image to enhance view.]
Or it may be feasible to replace the non-0-ring screws with the 0-ring versions, and thereby eliminate the need for any plugs.
Good Luck!
- redwood
- 81 650 CSR
- anarki650
- Thank you received: 5
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
The reported idle problem might be caused by having failed to correctly perform required bench sync with idle thumb screw at mid-way position during reassembly. This leaves adjusting room needed to further lower the slides when performing final sync and fine tuning pilot air screw settings.
Where this failure occurs, subsequent attempts to sync and/or set idle are frustrated because the thumb screw runs out of adjustment before the slides can be lowered enough for proper sync and low steady idle.
Good Luck!
- chance
- Life long biker/
You may have a look at one of the carbs the body and make sure its throttle slides works as it should . They can hang. I have found that about 1 out of 50 sets of carburetors I rebuild just won't work right after messing with them. It takes me over a day to do a set .
- redwood
- 81 650 CSR
