Carbs, Carbs, Oh those Carbs!!!
07 Feb 2010 12:41 #347116 by kilgore
Carbs, Carbs, Oh those Carbs!!! was created by kilgore
Took the old gal for a test drive the other day. Things went pretty well 'cept for the whole runnin' thing, lol! She was sputterring at low rpm accelleration, then hanging at mid-range (not returning to idle). I had cleaned the carbs earlier but have since learned about the choke system and don't think I got that quite right. To my knowledge, everything is stock (87 KZ1000 Police). Can't find much info on the Mikuni Round Slide carbs with throttle plates(?). I believe throttle cables and idle adjust thumbscrew were properly set. Any help is greatly appreciated, thanks!
07 Feb 2010 21:57 #347184 by timebomb33
Replied by timebomb33 on topic Carbs, Carbs, Oh those Carbs!!!
i would be looking at the pilot circuits again it sounds to me from the symptoms you have described that you still have a partial blockage somewhere in that circuit.
I THINK MY POWERBAND BROKE
  • TeK9iNe
  • What did you do!?!
18 Feb 2010 10:08 - 18 Feb 2010 10:11 #349001 by TeK9iNe
Replied by TeK9iNe on topic Carbs, Carbs, Oh those Carbs!!!
I would tend to agree with timebomb33 here...
Take the carbs off and do a complete teardown and thorough cleaning. Then reinstall them, and everything from the airbox tip to the exhaust tip AIR TIGHT.
Maybe this will help... 87 KZ1000P Mikuni BS34 CV carb diagram:
Good luck!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 18 Feb 2010 10:11 by TeK9iNe.
  • TeK9iNe
18 Feb 2010 10:16 #349004 by TeK9iNe
Carburetor Rack Assembly:
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
19 Feb 2010 17:53 #349224 by kilgore
Replied by kilgore on topic Carbs, Carbs, Oh those Carbs!!!
Thanks you guys! One big problem - <i> every single screw </i> at carb caps is frozen solid. Tried soaking in bolt remover oil and even a heat gun - no go. Gonna slap carbs back on and see what happens. I'm waiting on air box hoses and intake manifolds from Z1. I'd really rather not drill out all 16 screws at carb caps, so I'm keeping my fingers crossed!
  • Skyman
20 Feb 2010 00:00 #349263 by Skyman
Replied by Skyman on topic Carbs, Carbs, Oh those Carbs!!!
Can you get a grip on the screws with some vise grips? It will bung up the heads, so you'll need to replace them, but they're easy to replace.
West Linn, OR
20 Feb 2010 05:10 #349280 by 650ed
Replied by 650ed on topic Carbs, Carbs, Oh those Carbs!!!
try Kroil, they will loosen.
20 Feb 2010 05:47 #349281 by bill_wilcox100
Replied by bill_wilcox100 on topic Carbs, Carbs, Oh those Carbs!!!
You realize that the Japanese Philips screw driver is a different standard from the European Philips screw driver standard... close mind you, but no cigar.
That's why the screw drivers in the bikes tool kit always seem easier to use than the stuff from the local hardware store and why they don't damage the screw heads.
Someone else can pipe in with the official name for the two standards.
Best of success, :)
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
20 Feb 2010 17:06 #349345 by kilgore
Ahh... That felt good.
I bit the bullet and went ahead and drilled and EZ outed 14 screws ( 2 actually came off w/screwdriver). Needle jets were a little funky but all orifices were pretty clear. Cleaned everything up nice.
Now the hard part - waiting for UPS shipment of parts from Z1!
Thanks again everybody for the advice/help.
  • Skyman
20 Feb 2010 18:56 #349355 by Skyman
Best of success, :)
Bill
I believe you are referring to the JIS screw. They are usually identified by a raised (or indented) dot on the head face.
West Linn, OR
20 Feb 2010 21:17 #349382 by Patton
Replied by Patton on topic Carbs, Carbs, Oh those Carbs!!!
May wish to consider possibility of replacing with allen screws.
Good Luck! :)
21 Feb 2010 06:10 - 21 Feb 2010 06:18 #349399 by bill_wilcox100
Thanks Skyman "JIS" it is.
"Japanese Standards Association (JSA) promotes industrial standardization and quality control through development and publication of the Japanese Industrial Standards (JIS)..."
Patton wrote:
May wish to consider possibility of replacing with Allen screws.
Good Luck! :)
I bought a set of carb screws from Z1 and they worked fine. But looking back, I wish I had gone in the Stainless Steel Hex Head screw direction with mine. Maybe because KZR'ers are in and out of their carbs more often and the Hex Head is more user friendly both on-the-bike and on-the-bench.
Anyone gone in the SS Hex direction and if so what supplier, sizes and prices did you use? I know they will be much more expensive than the original Philips (star) screws but screws are not the most expensive things anyways.
Best of success, :)
Bill
Upgrades:
Montreal, Canada
Last edit: 21 Feb 2010 06:18 by bill_wilcox100.
