- Thank you received: 540
Where to go from here?
- MFolks
12 Dec 2009 15:57 #338672
by MFolks
Replied by MFolks on topic Where to go from here?
Take off the cover, and see if the mechanical ignition advancer will twist and then return to it's position.
If it sticks, lubrication with sewing machine oil or 3-in- one oil will help.
This advancer uses weights to control ignition advance/retard and needs periodic sevice.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
12 Dec 2009 23:19 #338736
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Where to go from here?
mookieo2 wrote:
As per suggested, remove throttle cable from carbs.
Check to make sure you have NO AIR LEAKS. Anywhere in the entire intake track, from filter to exhaust tip.
Spray with WD40 around intakes, etc. Not exhaust, if there was a leak there it would be a loud cracking sound.
Check the cam chain tensioner to make sure its operating properly.
Make sure float levels in carbs are correct/same.
You can get more info on this stuff in the search here...
Cheers, good luck.
I would blip the throttle and it would rev to 4k and stay there for a while.
Cheers, good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- mookieo2
13 Dec 2009 06:48 #338763
by mookieo2
Replied by mookieo2 on topic Where to go from here?
I think
This
is the problem I have. It started when it was at hot idle yesterday after I got it running pretty smooth. I wish the video still worked as I would like to verify the sound. I will check the advancer today, cam tensioner, then maybe try to sync the carbs if i get time.
- MFolks
13 Dec 2009 13:46 #338803
by MFolks
Carb sync. might take a while, so I'd suggest getting a fan to keep the engine cool, otherwise overheating can result with damaged engine parts.
