Where to go from here?
- mookieo2
I can get the bike to start and run but it takes a little gas sprayed in the carbs to kick over when its cold. After that it will run but it wants to run at 4k rpm. I can not get it to idle. I did once for a little while. Even when the choke is in all the way it will stay at 4k and then go down to about 1500 where I have the idle set up a little higher to keep it running. It shuts off shortly after. When It is warm it does the same thing.
What should I adjust or check first? The air fuel mixture screws on top were set to the factory 1 1/4 turns out.
Is air getting in somewhere? The vacuum lines are connected to the gas tank and the rest are plugged.
Should I try to sync them? It backfires pretty regularly but not loud just slightly out of the carbs.
- anarki650
- Thank you received: 5
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- mookieo2
- anarki650
09 Kawasaki ER6n
Omaha NE
- mookieo2
- anarki650
Also wouldn't be a bad idea to check valve clearances. Out of spec valves can make you think carb problems when you're not actually chasing carb issues...
09 Kawasaki ER6n
Omaha NE
- mookieo2
I read through a bunch of threads and decided to check the basice. First I disconnected the throttle cable. Bingo it must have been too tight. I can now get it to idle a steady 1500 for now. Its spitting out of carbs 1 and 2.
What should I adjust first? I bought the tubing to make the " Manometer" to sync them. Should I do this first or adjust the mixture screw in the back of the carbs.
- Thank you received: 2098
...spitting out of carbs 1 and 2.
What should I adjust first?...
Valve clearances, as suggested by anarki650.
And would check especially for too tight intakes.
Good Luck!
- mookieo2
- roy-b-boy-b
- Thank you received: 103
I would find the area where the clunking is comming from. Use a piece of wood held to your ear and place it in the area where you hear the noise.
Remove the throttle cable completly.
Keep in touch. Roy
- MFolks
- Thank you received: 540
If the bike has a standard igition, this is where the points will be.
- mookieo2
The mechanical ignition advancer might need some light oil in the pivot areas. It's under a CD sized cover on the right side of the engine. If the bike has electronic ignition, this is where the pick up coils are(Kawasaki calls them pulsing coils).
Not sure I understand why this would help? It has electronic ignition.
The clunk just started after it was running for a long time sitting in my driveway. The engine reved hard a few times I`m assuming from the throttle cable sticking. I hope its not too serious. The motor was recently rebuilt before it was put away for 8 years. I`ll try again tomorrow. I may have to post this new problem in another thread in the appropriate section.
