- Thank you received: 48
How to remove varnish from float bowl gasket
- JMKZHI
22 Nov 2009 18:21 #335254
by JMKZHI
Replied by JMKZHI on topic How to remove varnish from float bowl gasket
Z1Enterprises.com has them.
- otakar
23 Nov 2009 05:00 - 23 Nov 2009 05:10 #335317
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic How to remove varnish from float bowl gasket
Those are "O" rings for Keihin carbs and they must be replaced. Those deform with age and dry out. The cheapest I have found them is at Z1E for $14.50 You can try soaking yours in lemon oil, which you can find in the furniture polish section of the store. That is the only solvent which will not damage the Neoprene in any way and might allow it to go back into shape. When you wipe them be extremely careful so you do not stretch them. You can even BOIL them in the lemon oil. Just be very careful so it dose not catch fire on you while you are doing that. Personally I HATE Keihin carbs and I would not have a set on my bike. If you can, get a set of Mikunis on eBay.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 23 Nov 2009 05:10 by otakar.
- otakar
23 Nov 2009 05:12 - 23 Nov 2009 05:13 #335318
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Did you try soaking them in Carburetor cleaner?? "Sea Foam" is very good but others should be fine also.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 23 Nov 2009 05:13 by otakar.
