How to remove varnish from float bowl gasket
19 Nov 2009 04:48 #334576 by sakiguy
I can't seem to remove the traces of varnish off the float bowl gaskets. Tried wd40 and goo gone. Should I just soak them in gas for a bit?
1983 KZ750 N2 Shaft
19 Nov 2009 05:05 #334577 by otakar
If they have that much varnish on them that you have to worry about it, you should replace them.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
19 Nov 2009 06:49 #334595 by JMKZHI
So, I guess the gaskets are hard? You might try soaking them in silicone spray to soften them up. It worked for me so that I could work on the carbs, adjusting stuff n such. After getting them dialed in, I installed new gaskets.
20 Nov 2009 03:25 #334797 by sakiguy
Replied by sakiguy on topic How to remove varnish from float bowl gasket
Well if I can save them I'd rather do that instead of paying 17.50 for gaskets. I mean 17.50 for these gaskets seems a bit absurd.
1983 KZ750 N2 Shaft
20 Nov 2009 05:24 #334805 by otakar
No eBay APP ID and/or Cert ID defined in Kunena configurationI agree that 17.50 is a bit steep. That is why I do not pay that much. I am presuming that these are Mikuni BS34S? If they are try this.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
20 Nov 2009 05:30 #334807 by roy-b-boy-b
Replied by roy-b-boy-b on topic How to remove varnish from float bowl gasket
I put varnish on my old one to thicken them up ! :laugh:
20 Nov 2009 05:37 #334810 by otakar
No eBay APP ID and/or Cert ID defined in Kunena configurationBut personally I like this guys gaskets MUCH-MUCH better. They are of a lot better quality. If you will notice the price is for a quantity of (8)
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • newOld_kz1000
  • FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
20 Nov 2009 07:00 #334829 by newOld_kz1000
Replied by newOld_kz1000 on topic How to remove varnish from float bowl gasket
Wow, I certainly have been overpaying for gaskets!!
Never again.
OTAKAR: How do you make those eBay widgets like that? I'd like to be able to do that if I can help someone on the forum here by pointing out an impending eBay auction.....
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
20 Nov 2009 08:42 #334845 by otakar
The ebay item id given is invalid, no result has been sentThe ebay item id given is invalid, no result has been sentWhen you get to the page where you do your post entry, you will notice that in the toolbar there is a box that is marked eBay when you click it you will get this "" in between the two inside "][" paste the entire auction # "" That is all that's to it.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Kawickrice
20 Nov 2009 10:53 #334862 by Kawickrice
Replied by Kawickrice on topic How to remove varnish from float bowl gasket
The ebay item id given is invalid, no result has been sentThe ebay item id given is invalid, no result has been sentotakar wrote:
I never noticed the ebay tag, I always use the url tag.
I guess that you learn something everyday
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
20 Nov 2009 10:58 #334864 by otakar
:blush: Don't feel bad, I just found about it about two weeks ago. :silly:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
22 Nov 2009 16:23 #335238 by sakiguy
1983 KZ750 N2 Shaft
