KZ1300 carb kits... help?
- otakar
08 Nov 2009 16:36 - 08 Nov 2009 16:42 #332166
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic KZ1300 carb kits... help?
You might just have a stuck ring. Get your self a can of "Mopar Combustion Chamber cleaner" Part #04318001AB at any Mopar dealer. Do not let yourself get talked into any other "stuff" this is by far the best and quickest working. Start the engine and let it heat up. Remove the suspect spark plug and spray into the cylinder about a 3-4 second burst than immediately replace the spark plug. Allow to sit for about an hour and repeat the process about 4-5 times. After the first application rev the engine a bunch of times or take it for a brisk ride until the engine is at full temperature. If the ring or rings are stuck, this should free them up. You may also have an improperly adjusted valve at that cylinder which is staying open by only a Thou of an inch or so. this will also be sealed with your oil treatment. You may also have a slightly bent valve.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 08 Nov 2009 16:42 by otakar.
- otakar
08 Nov 2009 16:54 #332172
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
I have two of these things and pulling the top end off of this thing is a pain in the ASS (quite time consuming) I would do my best to determine what the problem exactly was before you tare into it.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Thank you received: 2098
08 Nov 2009 19:22 #332238
by Patton
Replied by Patton on topic KZ1300 carb kits... help?
If valve gap adjustment doesn't bring compression to cyl #5, would perform leakdown test to determine where compression is escaping.
Good Luck!
Good Luck!
