KZ1300 carb kits... help?
29 Oct 2009 18:57 #330398 by tomsweb1
KZ1300 carb kits... help? was created by tomsweb1
Hey guys,
I'm having alot of trouble locating carb rebuild kits for my 82 kz1300. Anywhere I do find them, they're sold out.
Does anyone out there know where to find them?
Thanks in advance!
1978 CB400A Hondamatic
1983 CB550SC Nighthawk
1978 CB750A Hondamatic
1982 KZ1300
29 Oct 2009 19:32 #330406 by Patton
Replied by Patton on topic KZ1300 carb kits... help?
If not already done, could inquire at Z1E via email parts inquiry or phone.
Z1E may be able to obtain parts not shown on its web site, or refer to an alternate source.
Click here > Z1E Contact Information
Good Luck! :)
30 Oct 2009 05:30 - 30 Oct 2009 05:45 #330456 by otakar
Replied by otakar on topic KZ1300 carb kits... help?
Keyster kit # KK-0162NR. You will have to see who caries them. Try to contact this guy on eBay, He is the only one who I have ever seen with them and I have bought about 9 sets from him in the past.
cgi.ebay.com/ebaymotors/KAWASAKI-KZ1300-...TL0910081510002r4858
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 30 Oct 2009 05:45 by otakar.
03 Nov 2009 19:33 #331392 by tomsweb1
Replied by tomsweb1 on topic KZ1300 carb kits... help?
hmm, the guy at Z1 said they don't exist. He suggested I buy a Z1, then he could get me all the parts I ever wanted, haha! (I had previously asked him about another imppossible to find part for my 750 Hondamatic)
Siriusco doesn't appear to have any in stock, but I will send them and e-mail soon.
Thanks for the suggestions, guys!
1982 KZ1300
04 Nov 2009 03:45 - 04 Nov 2009 03:47 #331419 by otakar
Everything exists, you just have to take the time to find it. You would be surprised at what you can find if you look hard enough. There are just not that many KZ1300s around, so dealers just don't bother carrying parts for them because it is not economically feasible. You just have to do the leg work yourself.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 04 Nov 2009 03:47 by otakar.
04 Nov 2009 05:20 #331435 by tomsweb1
I pulled the carbs and gave them a good clean. Everythin appears to be in good shape, with the exception of the rubber parts.
Is it possible to make ne float bowl gaskets? I'm sure I can get o-rings to replace the old ones... or are they something special?
1982 KZ1300
04 Nov 2009 07:13 - 04 Nov 2009 07:41 #331460 by otakar
No eBay APP ID and/or Cert ID defined in Kunena configurationMake sure that "O" rings are "Viton@" (Fluorocarbon)and float bole gaskets are readily available. They come in ALL of your KZ1300 gasket sets. Do not reuse the old dry gaskets, they will leak. Replace all of them.
Also replace the air valves on the side of each carburetor and the fuel valve connected to each float. The fuel valves are a must. Replace the O rings on the air needles and all plugs. AND FOR GODS SAKE make sure that ALL of the fuel and air passages are clear. These carbs are notorious in clogging up. I have worked on these carbs since 1979 when I bought my first 1300, and worked for a Kawasaki dealer, and they are quite a bit more cantankerous than other CV carbs. While replacing the lower fuel valves be very careful, they are usually stuck and you can do a lot of damage attempting to remove them. I have a special tool to do this, but many guys insist on pliers, and wind up destroying the carburetors in the process. Make sure you blow into any and all ports and passages with dry air to make sure they are flowing properly. I use a special Hydraulic pump to blow threw any obstructions.
Last but not least, if you are rebuilding these carburetors because the engine is running rough or one or more cylinders is not running at all, it may not be the carburetors at all, but your ignition. These bikes are notorious on cracking ignition coils or burning up pick up coils. I have also burned out a FEW alternator stators on these bikes. The alternator is very week for the power consumption of this bike.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 04 Nov 2009 07:41 by otakar.
08 Nov 2009 09:00 #332115 by tomsweb1
Crap... that's exactly why I want to rebuild the carbs. Well, I guess I'm checking the coils today...
BTW, thanks for the link, but he doesn't ship to Canada. No one else has these either.
1982 KZ1300
08 Nov 2009 10:46 #332125 by MFolks
Replied by MFolks on topic KZ1300 carb kits... help?
Look here:http://www.z1enterprises.com/detail.aspx?ID=3952
08 Nov 2009 14:01 #332148 by otakar
Z1 did not have them the other day. Actually they were the ons that said that they do not exist. I guess it helps when someone gives them the Part #. I would much rather buy from Z1, their prices can not be beat by anyone. I guess this particular thread has just done a big favor to 1300 owners.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
08 Nov 2009 14:06 #332150 by otakar
Hay TOMSWEB1 just be very careful with these the BSW32s are quite a bit more tricky than other carbs. If you just want a set of float gaskets I can bid on them and send them to you.
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
08 Nov 2009 16:14 #332163 by tomsweb1
Thanks for the offer otakar, but I just found out that there is no compression in #5, so this project is going to have to sit until spring... The snow is coming, I don;t have a garage, and I'm out of cash... *sigh* California should share some of thier weather with us.
I think once it thaws, I will be getting a kit from Z1, though. What a crazy good price for these kits! That is, of course, if I can salvage whatever is wrong with #5. I think it's the rings, poured oil in and got the same compression as the others.
Thanks for all the great info guys, I'll see you in the spring!
1982 KZ1300
