SOLVED! 650 w/750 juggs. Runs on choke only.
- FloridaSteve
i had cleaned my 29 smoothbores with spray and air,because of dirty running and changing idles...and somehow clogged the idle circuits,,,while cleaning em!!!!!....and was sure i had em nailed...but my symptoms were as you describe to a word....i posted and was told what t.b said and others......i re-did em once more with fine wires to pass through all removable parts in a dish of carb cleaner,, and was extra, extra picky, and looking for missed fittings or holes/passages,of which a found an area that i had missed beofre,tiny passage ports....the guys were right!!! and it now idled perfect once set...pulled clean like never before...and did not pop and crackle as before under a load in downshifts.....so to repeat...you'll get to em i bet....and be soooooooo happy when you do...imo...
You're right. I did not go through it to this level of detail. I'll have them off again tonight and start back on it. I'm sure if this isn't THE cause it's still going to need to be cleaned better. I know that just soaking them didn't get them THAT clean. Here I go one more time!
mark1122 wrote:
I have had to drill out the brass bead that plugs the OEM hole before. I can’t remember if that is necessary on that model, but it is an easy fix. Just plug the hole back up when done. This can be done with a small round lead fishing sinker weight, or whatever u have on hand.
Mark I'm a little confused on this. I'm positive that my carbs have air jets in them which I'll have to deal with carefully. I don't know of any closed off passages that would deal with the pilot circuit. These are the carb model I'm using.
- FloridaSteve
- kwak650
- trianglelaguna
- Thank you received: 235
note: i used strands of copper elec braids...and it required different guages...ie...woven speaker wire....woven lamp cord..in single sepereated strands/thickness....be super careful to go slow and not pinch/break a wire in the brass holes....i lnow it is self evident but still...it makes a whole new problem...i used a ceramic bowl and strands of copper and carb cleaner....but the idle circuits are cast into the carb bodies and require repeated soaks/sprays/and blowing out....i think was where i got er done in the end...good luck
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- JMKZHI
- Thank you received: 48
- FloridaSteve
You might want to look into getting the electronic ignition for a 750-4.
Oh that will be a given. I love old bikes and I know a lot of folks are sentimental about them but personally I can't stand points. I have electronic ignitions on some ancient RD400 yamaha 2-strokes that I havn't removed the cover from in 6 years and they start first kick.
- FloridaSteve
Just a stupid question but are the carbs filling with gas.(petcock working properly).
Not a stupid question at all. It's often that kind of overlooked thng that kills you. Been there done that. I pulled the bowls last night and they were gettig a good flow.
- Thank you received: 2098
With functional choke circuit, starting fluid shouldn't be needed. Initial cold-starting engine should be done without even touching the throttle grip. The enrichment circuit is designed to operate with the throttle slides all the way down in idle position. Don't "crack" the throttle; and don't work it back and forth. Just leave it alone. Might need to adjust thumb screw to set slightly higher idle position.
It's of course possible that a passage in the choke circuit is blocked or clogged, which is its own circuit, separate and apart from the pilot circuit.
These earlier threads may be of interest with some more info about the pilot circuit, cleaning, etc.
Pilot Circuit
More pilot circuit
New pilot jets are relatively inexpensive, and may help even though the existing pilot jets look perfectly okay.
Good Luck!
PLEASE WEAR EYE PROTECTION WHILE SPRAYING CARB CLEANER.
[Click on image to enhance view]
- FloridaSteve
Thanks again!
- ArthurGoVroom
- I'd rather ride it than shine it
1976 KZ900A4, 4-1 header, rear lowering kit, grab bar removed, still shining and painting parts as time permits
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- FloridaSteve
The bike still will not fire off anything but a full battery charge, fast turnover on full choak with a squirt of fuel in the bellmouths to get her going and then will die off of choke. Also the bike won't run at all on my known good KZ650 carbs.
Here's what I'm thinking:
Is it possible that I set my cam chain incorrectly on the rebuild? If I'm off one tooth could this account for the behavior? Would she just barely run like this with the advance (or retard) that I would get from this error. Would the valves clear with a one link skip?
I have 20 and 22.5 pilots on the way but I'm at a loss here that I'm getting squat as far as this engine firing off at all.
I freaking stumped...
EDIT: I just remembered something relating to the possible cam chain issue. At one point while trying to start the engine, I put my hand over the carbs to check the vacuum. There is an outward blow before the vacuum cycle. I'm normally riding 2-strokes so cut me some slack on this stupid question but Is this normal?
