Kz750 carb overflowing
- chance
- Life long biker/
30 Aug 2009 06:18 #317531
by chance
Replied by chance on topic Kz750 carb overflowing
I agree 100 % sorry I didn't see you wrote the same thing basicly.., Chance
- Thank you received: 2098
30 Aug 2009 07:51 - 30 Aug 2009 07:51 #317540
by Patton
Replied by Patton on topic Kz750 carb overflowing
Wondering if lack of combustion in #4 might be for some other reason besides a carb problem.
Such as ignition (eg., spark quality) or compression (eg., valve cleanance).
If not already done, would remove #4 plug and visually inspect spark quality.
While plug is removed, would do a compression test (remember to hold throttle wide open during test).
And for good measure, install a brand new plug.
If problem persists, re-address carb situation.
Good Luck!
Good Luck!
Last edit: 30 Aug 2009 07:51 by Patton.
- szczupd
- !!!NEVER BACK DOWN!!!
30 Aug 2009 10:09 #317573
by szczupd
Most motorcycle problems are caused by the nut that connects the handlebars to the saddle
1982 KZ750H LTD
Replied by szczupd on topic Kz750 carb overflowing
Patton wrote:
thats the first thing I did new plugs and have good spark
Good Luck!
1982 KZ750H LTD
