Kz750 carb overflowing
  • szczupd
  • Topic Author
  • !!!NEVER BACK DOWN!!!
29 Aug 2009 18:28 #317439 by szczupd
Kz750 carb overflowing was created by szczupd
Maybe someone can help me I adjusted the carburetor float hight as specified in the manual. I start the bike with no problems but the carbs still overflow and not all of them the only one that doesn;t overflow is the only cylinder that doesnt get warm?/? 1 2 3 cylinders get hot no problem and the carbs keep overflowing can anyone shoot some wisdom over my way Thanks Guys
Most motorcycle problems are caused by the nut that connects the handlebars to the saddle
1982 KZ750H LTD
29 Aug 2009 18:34 #317441 by chance
Replied by chance on topic Kz750 carb overflowing
How did you set the floats ??Fuel service method or with a gauge..
  • szczupd
  • Topic Author
29 Aug 2009 18:42 #317443 by szczupd
Replied by szczupd on topic Kz750 carb overflowing
using the clear tube and checking the hieght against the body of the carburetor
1982 KZ750H LTD
29 Aug 2009 18:44 #317444 by chance
What did you set the height at?
  • szczupd
  • Topic Author
29 Aug 2009 18:47 #317445 by szczupd
i set them all within .016 of the top of the bowl
1982 KZ750H LTD
29 Aug 2009 18:56 #317447 by 650ed
Replied by 650ed on topic Kz750 carb overflowing
I believe it can only be one of 3 things (but I could be wrong). 1. The float tang height is actually set a bit lower than the other 3 carbs. Did you use the clear tube method? If you did and it still leaks see next 2 possibilities 2. The float valve is not seating properly. Remove the little float valve needle and clean it and its seat with carb cleaner or some other non-abrasive cleaner; replace if damaged. 3. The overflow tube in the carb bowl is cracked or lose. Check this while you have the carb bowl off to clean float valve. Ed
29 Aug 2009 18:58 #317448 by chance
Should be 4mm below the top of the bowl.
29 Aug 2009 21:16 - 29 Aug 2009 21:20 #317470 by bill_wilcox100
Replied by bill_wilcox100 on topic Kz750 carb overflowing
szczupd, on my KZ650-B1 the Fuel Service Level is spec'ed at:
2.5 to 4 mm
or
0.0984 to 0.180 inches
or
0.01 to 0.18 inches (rounded to nearest 1/100th of an inch)
or
1/100 to 1.8/100th of an inch.
or
Measure against Float Bowl flange reference point (see below):
Best of success. :)
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 29 Aug 2009 21:20 by bill_wilcox100.
  • szczupd
  • Topic Author
29 Aug 2009 23:39 #317482 by szczupd
alright i cant figure this thing out all the carbs are at the right hight and the needles seat 1 and 2 still overflow and cylinder 4 doesnt get hot arghhhhhhh!!!
1982 KZ750H LTD
30 Aug 2009 03:40 #317510 by fixer5000
Replied by fixer5000 on topic Kz750 carb overflowing
maybe the choke well in #4 is plugged up? i had this problem with mine waaaay back when i got it. took the carbs out 3 times to figure it out. maybe its time to remove and replace the inlet needles and seats
1978 kz650b pretty much stock
massachusetts
30 Aug 2009 04:54 #317514 by chance
Floats sre too high, float needles are bad , Float feedles have trash in em 4 must have a clogged pilot .. Tha only way they will overflow is float needles leaking or float level too high..If you have the float levels right it shouldn't leak
30 Aug 2009 05:22 #317520 by 650ed
szczupd wrote: "alright i cant figure this thing out all the carbs are at the right hight and the needles seat 1 and 2 still overflow and cylinder 4 doesnt get hot arghhhhhhh!!!"
I don't get it? There's nothing to "figure out." See my reply above, try what I suggest, and your carb won't overflow. Ed
