- Thank you received: 1
1st time prob=frustrated!!!!
- Z1109R Fin
28 Aug 2009 04:38 #316931
by Z1109R Fin
Z1000R ´83...Slightly modified...
Replied by Z1109R Fin on topic 1st time prob=frustrated!!!!
Check one thing first. The bracket holding cables may have got little loose and may be jamming the throttle retainer spring and making slides stick. This happened to me once.
- Kawiman80
- On my 2nd KZ1000
- Thank you received: 3
01 Sep 2009 17:19 #318339
by Kawiman80
1980 kz1000g 1105 34mm Mikuni flat slides Kerker exhaust custom paint stock ignition(Dyna 2000 soon) Accel coils and wires stock cams w/ heavy springs for more rpm. My 2nd 1000.
Replied by Kawiman80 on topic 1st time prob=frustrated!!!!
Hey guys,
Thanks for all of your advice on this subject. I took off the carbs this weekend,cleaned them,inspected the boots(they will work till ridin season is over=no leakage). Then I installed them and got the same problem of sticking,WTF!!!
I just looked into the throttle itself and found afrayed cable!!!! I replaced it and no sticking issues. Who would've thought.
Again thanks,
Mike
Again thanks,
Mike
- timebomb33
- Thank you received: 10
01 Sep 2009 17:29 #318347
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 1st time prob=frustrated!!!!
k.i.s.s always some thing foolish isn't it. i've seen guy's pull a whole bike apart tryingf to find an electrical problem when staring them in the face the whole time was a blown fuse. always the easy thing.
- Kawiman80
- On my 2nd KZ1000
02 Sep 2009 18:20 #318698
by Kawiman80
Update on k.i.s.s.....per timebomb33
The frayed cable wasn't the only issue!!
I TRIED to go for a ride today,when I fired it up the exhaust note sounded different. Not as deep as usual and the sticking throttle was back. Took of carbs to see what was up and found to my dissmay,the #4 sync adjuster had came loose,hence the sticking throttle. It was catching the needle a little and then letting go!!!
Fixed that and synced the carbs and viola,perfect running KZ!!!
I put a little thread locker on all of them so I shouldn't have a problem for a while,I hope.
Has this happened to anyone else before?
Mike
Mike
- Kawiman80
- On my 2nd KZ1000
31 Jan 2010 12:11 #345617
by Kawiman80
Ok guys,
I have a new problem! I keep fouling my plugs on all the cylinders. Thick,black carbon. I tried cleaning the plugs,but no diffrence. This has happened twice now. Battery is fully charged and timing is set. The air mixture screws are out 1.5 turns and runs good,but only fouls at start up after sitting. And also is hard to start after riding(good and warmed up) and stopping for an 1hr or so and then restarting. Please help. It is very aggravating.
I remember seeing this same problem on here,but can't find it.
Thanks,
Mike
Thanks,
Mike
- jeffasaki
- Thank you received: 44
31 Jan 2010 12:31 #345620
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Replied by jeffasaki on topic 1st time prob=frustrated!!!!
Hard starting after the bike has been sitting hot for an hr or so.Try putting your petcock to prime let it stay like that for a few seconds,then try.I had the same problem with one of my bikes and this cured the problem.Ithink the float bowl levels get low after sitting hot and take time to fill up again.Carbon fouling may be caused buy worn valve stem seals,or guides.And if youre trying to start with low bowl levels the bike may be trying to burn any oil that has bypassed while sitting.Just my thoughts
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Kawiman80
- On my 2nd KZ1000
03 Feb 2010 22:29 #346354
by Kawiman80
Thanks jeff,
I'll double check the float levels to make sure the are not to low or maybe to high.
I know I have seen something on here about the mixture screws,they might work in reverse on these carbs? Turn them out makes them richer,or something like that.
I am not burning any oil at all. Motor was freshened up before I bought it.
Thanks,
Mike
Thanks,
Mike
- Kawiman80
- On my 2nd KZ1000
07 Feb 2010 19:13 #347163
by Kawiman80
Float levels are ok. Please help me out guys!!! I went to Mikunis site and couldn't find anything on this. I have searched for this problem on here and I must not be typing in the right info for the search.
If anyone has experienced this problem,please help out.
Thanks,
Mike
Thanks,
Mike
- roy-b-boy-b
- Thank you received: 103
08 Feb 2010 04:49 #347198
by roy-b-boy-b
Replied by roy-b-boy-b on topic 1st time prob=frustrated!!!!
Did your carbs come with the plug over the pilot jet?
Some 34's require the plug to be there some don't. Roy
- Kawiman80
- On my 2nd KZ1000
14 Feb 2010 18:14 #348308
by Kawiman80
No roy it doesn't. i'll try to figure it out when ridin' season gets here.
- rnuse
- Balls to the walls, sideways all the time
14 Feb 2010 19:04 #348325
by rnuse
1982 kz750 ltd
Drag bars, 4into1 V&H with no baffle.
1991 zephyr 550
about to give up on her.
Replied by rnuse on topic 1st time prob=frustrated!!!!
Double check your timing. Does it begin to run bad as your riding? Or only when trying to start it? Spark might be bad. Search the coil fix on here.
1982 kz750 ltd
1991 zephyr 550
- roy-b-boy-b
14 Feb 2010 19:21 #348332
by roy-b-boy-b
Is this the bike in your signiture. G1? Does it still have the fuelie head?
Do you have a manual petcock or vacum? Roy
