- Thank you received: 3
1st time prob=frustrated!!!!
- Kawiman80
- On my 2nd KZ1000
I have a set of 36mm Mikunis on my 1105 and know they are sticking on high idle and then releasing. I have adjusted the cables,cleaned and sprayed the shafts with wd-40. Nothing has changed. It's acting like there is no shut off cable attached,but it is. And there is no bottom end when you crack the throttle,it dies. Almost like a vaccuum leak somewhere. I checked for that to.
PLEASE HELP!!!
Thanks
Mike
1980 kz1000g 1105 34mm Mikuni flat slides Kerker exhaust custom paint stock ignition(Dyna 2000 soon) Accel coils and wires stock cams w/ heavy springs for more rpm. My 2nd 1000.
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Old Man Rock
- Thank you received: 225
If so, time for new ones...
A trick I've been using with good results... Put some vacuum grease around the carb mounts for insertion into the boots... Seals them up nicely thus no leaks!
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Kawiman80
- On my 2nd KZ1000
Anyone got any for sale??? I'll check Z1 or Clem's Kawasaki,there are close to where I live.
Thanks,
Mike
- PLUMMEN
- Thank you received: 104
- saxjonz
- KawboyZ
- Thank you received: 76
79 LTD B3
- timebomb33
- Headly
73z1a fireblade front&rear,75z1b,74z1a,05 husky 510,xl567.
Ask the toe cutter,he knows who i am!
- Thank you received: 2098
...36mm Mikunis on my 1105...sticking on high idle and then releasing. I have adjusted the cables,cleaned and sprayed the shafts with wd-40. Nothing has changed. It's acting like there is no shut off cable attached,but it is. And there is no bottom end when you crack the throttle,it dies. Almost like a vaccuum leak somewhere. I checked for that to....
Possibly not carb-related.
Would also assure ignition advancer is properly functioning, and not hanging in advanced position for whatever reason.
Can use a timing light while engine's running to watch the advancer in action as it moves back and forth when the throttle is blipped. The change in advancer position should be instantaneous with changing rpm.
If sticking, sometimes a little squirt of oil will loosen it up. But it's usually best to remove it for cleaning, inspection, and re-lube with moly-grease.
Good Luck!
- Old Man Rock
Seriously, unless drag racing, 29-31mm is more than sufficient for that size motor on a street ride....
Question, in your signature, you had 34mm carbs listed, you still have them to install and test with?
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- donthekawguy
- Thank you received: 8
Just out of curiosity, why such BIG carbs on a 1105 motor?
My thoughts also.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- Kawiman80
- On my 2nd KZ1000
They are 34's I must have FAT fingered the buttons and got in a hurry. Thanks for the catch OMR.
There is more to this besides the manifolds. I looked into it yesterday and found that they are sticking without running. Looks like a carb rebuild and new manifolds!!!!
I know the 34's are probably to big for the street also,but they were on there when I bought it and haven't changed them. It has been running good until a few days ago.
Thanks for all your input and advice,it has been greatly appreciated.
Mike
