- Thank you received: 1
Ahhh found a crack! What would you do?
- 550A2
- keep the shiny side up
I also tightened up the boots, it runs alot better.
ill gen some new boots with the next check i get.
Although the cracks are eliminated now i have a ticking noise below 3,000 rpm. i dont know what it is, and its very annoying.
the valve clearances are all in spec so that cant be it, i hope its not the cam or crank bearings!!!!!!!!!1
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
- nads.com
- Thank you received: 20
- loudhvx
- Thank you received: 1616
I brushed on a layer of form a gasket sealer let it dry then brushed on some black rtv. The gasket sealer should hold up against the gas i am hoping, and the rtv will protect the gasket sealer from water....It seemed to work just fine.
When you check the valve clearances, you have to loosen the cam chain tensioner before puttin gth evalve cover back on. If you don't, the chain gets stretched by the valve cover and the guides get worn. There is a warning in most manuals about this.
If the chain is stretched, that could cause some ticking.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- 550A2
on my way home i was crusing down my road and i probibly got er up to 7 grand in 4th... when i pull in my driveway the fucking thing lost all its power and it sounds like its running on 1 cylinder!!!!!!!!
I got it in my shop shut it off and tried to start it again, it barley starts! but once it started it ran like shit.
I checked it for spark and im good there, but i need to do a comprression test. I think its a problem with the carbs. But it just suddenly appeared so i dont know what it could be.
ALSO: when i pulled it in my shop it smelt really rich like gas.
This is my only transportation to college and back and i need it! i dont know what to do
someone please help!
- 550A2
- Thank you received: 2098
ok, i just tried to run it again, it started fine and ran good for a second then fuel started (pouring) out of both overflow tubes. then it ran like crap again. and the petcock wasnt in the prime position.
fuel started (pouring) out of both overflow tubes --- would suspect malfunctioning float valves. Is an inline fuel filter being used?
Good Luck!
- 550A2
I drained them and started it back up. they must have got stuck.
Its just wierd more then one would stick at the same time?
I filled up today, maybe i must have got some crap in the fuell or something.
No fuel filter is being used, i have the vaccum fed petcock and the fuel line is straight.
I should probably use one huh? in addition to draining the tank and flushing it of all crap, and maybe cleaning out my petcock.
I think that should help
this site kicks ass, thanks guys!
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- 550A2
- toadson
One of the boots is cracking around the vacuum nipple, so I'm wondering if that is causing one of my cylinders to run lean. Now I have to decide whether to buy new ones or try to fix these. Did yours look as bad as mine?
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
- 550A2
But mine being stock and 30 years old im sure they are not too far from that.
Im gonna order some today.
