- Thank you received: 1
Ahhh found a crack! What would you do?
- 550A2
- keep the shiny side up
it still ran like it had a vaccum leak, but none turned up. Then today i thought to look at the boots from the head to the carbs.
Sure egnough, there is a crack in cyl #4 boot. I sprayed some carb cleaner on it when it was running and it started choking.
Im glad i found it!
But does anyone have any suggetions on a quick fix until i can score some new boots???
thanks
Luke
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
- 550A2
- mzandmz
New to Family, 1979 KZ440 LTD
- mzandmz
- Royal1MC
- Is it just me, or is it just great to be on a KZ
Part # 16065-1014 is showing active under Item Status Code.
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
- 550A2
I have an 82 kz550 a2.
i put some on so hopefully it runs a little better in the mornin.
Ill check these babys out though, see what kind of deals i prices i can get.
Thanks again.
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- trianglelaguna
- Thank you received: 235
does z-1 enterprises.com sell em for your model they are great on price and ship super fast for like ten bucks and will sell you the right one the first time......i dig getting stuff from em.....p.s there carb clamps are gun metal black and are a great deal too...new screws.....woohoo it's fun to spend money....but seriously you got some extra cracks?????
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- 550A2
There 86 bucks though....fak! kinda pricey for rubber flanges.
ill have to get them though, then get a sync.....
that should do the trick.
ehhhh, no crack smokin here, just crack sealin.
lol
dave chappele is the shit.
- TerryK
Yeah, i found them!
lol
You think that's pricy? Check the OEM Kawasaki ones. It'll scare you into buying the aftermarket ones.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- mkeating
I also have some cracks in my boots and I plan on using gorilla glue or elmers ultimate glue to bond the inside of the crack together. From there I am simply going to use some plastidip and apply a very thin coat over the crack with a small brush. Many people have used this for diaphragm repair, but I have also heard of it being used for carb boots as well. I am not sure where you are from, in the states you can get plastidip at Napa and Home Depot. In Canada I found some at Home Hardware. You can check their site at plastidip.com. Also for past stories on the use of this stuff check :
www.kawasakimotorcycle.org/forum/vintage...gm-repair-works.html
or this link talks about using it for carb boots:
www.xs11.com/forum/showthread.php?p=2972
Let me know how you make out. I will be doing mine this weekend!
- Ironhorse
- www.ridelikeaprowestcoast.com
Real learning begins after you know everything.
