- Thank you received: 1581
Forced induction guys. What carb and jet ?
- zed1015
- PLUMMEN
- Thank you received: 104
- Jeff.Saunders
220 main jet, 35 or 37.5 pilot jet
www.z1enterprises.com
Z1 Ent on Facebook,
- kano
- Not Another Bloody Limey!
- zed1015
I run an HSR 42 carb on a 1200cc turbo Z1.
Mmmm! Looks like i could be in the right region with the 180 thats currently in ?
- Jeff.Saunders
you still got the turbo then jeff?
yup...
I don't have any experience with a Supercharger on a KZ, but I would expect the fuel demands to be similar to the turbo setup. I would think around 200 would be a good starting point. 180 would be close enough to fire up, but might be a little lean. Much will depend on the drive ratio you use on the street - that's the one thing with the supercharger that's a pain to tweak.
What ignition setup are you planning on running? I have the Dyna 2000 on the turbo. The new version of the 2000 are programmable from a computer, so you can tweak the advance/retard curves to tailor the setup.
Z1 Ent on Facebook,
- zed1015
Just running the basic Dyna 'S' currently timed at 35 deg full adv with four 1.5ohm coils for the twin plugged head and a Dyna rev limiter.
- PLUMMEN
- zed1015
- supercharged
Need to compliment you on the bike - looks GREAT!
Did you make the pulley cover? I may have a reason to get you the 15lbs pulleys, since I need a trick cover;)
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
- zed1015
Not to ignore your post - but i'm running a true bone stock Drouin set-up. No carb, just a manual throttle body with a dial-in jetting.
Hi. The pulley cover is the original Drouin one with some holes in. Did have a go at making my own but it just did not look right so bit the bullet and cut the original.
What sort of fuel consuption are you getting with the stock throttle body ?.
