teflon and gas
  • Iron Duke
  • Topic Author
  • what are you rebelling against?
05 Jul 2009 22:55 #304690 by Iron Duke
teflon and gas was created by Iron Duke
After the last time cleaning tank,pulling petcock,reinstalled ,fresh petro and put teflon tape around threads on petcock for seal, teflon is being eaten away by gas looks like it might start leaking anytime. Question is is there something else that can be used to seal, and make sure no leaks happen ? ?
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
06 Jul 2009 05:08 #304697 by Locozuna
Replied by Locozuna on topic teflon and gas
Some say the yellow Teflon tape is gas resistant. But don't use the white.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • Iron Duke
  • Topic Author
06 Jul 2009 11:29 #304758 by Iron Duke
Replied by Iron Duke on topic teflon and gas
Logan Thanks for the reply, but was more in mind of a paste,silicone,maybe something out of a tube, help any? any help? thanks to all who submit. G.W.
1982 KZ550 LTD C-3
06 Jul 2009 11:33 #304762 by PLUMMEN
Replied by PLUMMEN on topic teflon and gas
maybe try rector seal# 5 first then try some yellow tape with another coat of rector seal before you screw it together,thats the only way i use teflon tape on anything B)
06 Jul 2009 12:59 #304790 by Locozuna
Have used Yamabond and Seal All with good results.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
06 Jul 2009 14:41 #304817 by bountyhunter
Replied by bountyhunter on topic teflon and gas
Silicone rubber is not gas resistant. gas eats it.
06 Jul 2009 14:54 #304827 by gane
Replied by gane on topic teflon and gas
Iron Duke, Petcocks of the spigot variey seal via a rubber seal from spigot to body and are secured with a l/h-r/h threaded nut. bolt on Petcocks seal via a goofy bridged o ring/gasket and shouldered bolts using either plastic or fibre washers. all should be avail. stock or from Z1 ent.Personaly have no faith in tape or sealers living in gas envirne, luck G
[img][/img] 1977 KZ1000A1
06 Jul 2009 17:15 #304869 by leorider
Replied by leorider on topic teflon and gas
Permatex Ultra Black.
78 KZ650B
  • TeK9iNe
  • What did you do!?!
06 Jul 2009 19:08 #304907 by TeK9iNe
Replied by TeK9iNe on topic teflon and gas
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
06 Jul 2009 20:01 #304927 by Old Man Rock
Replied by Old Man Rock on topic teflon and gas
"rectal seal# 5"... :blink:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
06 Jul 2009 20:39 #304936 by PLUMMEN
thats rector seal you action figure stunt double! :laugh:
  • Iron Duke
  • Topic Author
06 Jul 2009 22:11 #304952 by Iron Duke
Thanks guys for all the input sure this will take care of my problem. permanently.
1982 KZ550 LTD C-3
