- Thank you received: 48
1981 kz650 carb. question please help!!!
- JMKZHI
30 Jun 2009 19:57 #303506
by JMKZHI
Replied by JMKZHI on topic 1981 kz650 carb. question please help!!!
Just an FYI: the 81 KZ650-CSR doesn't have the handy tubing guide for routing them.
- CPUCK
14 Jul 2009 18:12 #307060
by CPUCK
Replied by CPUCK on topic 1981 kz650 carb. question please help!!!
so on carb #2 is there two overflow tubes or is one for air flow??
- JMKZHI
14 Jul 2009 19:40 #307088
by JMKZHI
It's been a while & I'm not 100% sure, but I believe one of those lines is an overflow & the other one is for checking the fuel level. On the other 3 carbs, the overflow & fuel level check use the same orifice/nipple.
- Bluemeanie
- Thank you received: 14
14 Jul 2009 20:13 #307105
by Bluemeanie
Replied by Bluemeanie on topic 1981 kz650 carb. question please help!!!
CPUCK wrote:
Are you talking about the vacuum port for the petcock?
- CPUCK
14 Jul 2009 20:32 #307110
by CPUCK
no im talking about the overflow valves on the bottom, and the second float bowl has 2 so i was wondering if both are overflow but like JMKZHI said it might be the fuel level check. is he correct? if so will fuel leak out of it? do i need to run a tube off of it?
- JMKZHI
15 Jul 2009 06:02 #307152
by JMKZHI
I have tubing on both of those ports.
You could do a test. Raise the tubes above the carbs & blow into them one at a time. The one that's open is the overflow. For the other one, unscrew the drain screw several turns & blow again. If it's now open, then that one would be the fuel level check (or carb drain).
- JMKZHI
15 Jul 2009 06:05 #307153
by JMKZHI
The port nearest to the accelerator pump is the carb overflow (fairly sure - but not positive).
- Bluemeanie
16 Jul 2009 06:00 #307347
by Bluemeanie
- JMKZHI
16 Jul 2009 07:04 #307360
by JMKZHI
Another interesting difference is that the 81 model doesn't use the triangular vacuum sensor (& the orifice is plugged).
