1981 kz650 carb. question please help!!!
21 Jun 2009 13:33 #301099 by CPUCK
hey guys im working on a 1981 650 csr and i took apart and cleaned the mikuni vm24ss carborators and i forgot where all the fuel tubing needs to be hooked up for proper flow. is there a diagram that anyone has to show me for some help?
21 Jun 2009 14:20 #301114 by timebomb33
Replied by timebomb33 on topic 1981 kz650 carb. question please help!!!
how many spigots are there coming out of the carbs. one large one in the middle should be for the fuel inlet the two out side ones should be bowl vents , vented to the atmosphere and the smaller one to the inside of the right side vent should be for a vacuam fitting for the petcock.
I THINK MY POWERBAND BROKE
22 Jun 2009 05:55 - 22 Jun 2009 05:55 #301279 by Bluemeanie
Replied by Bluemeanie on topic 1981 kz650 carb. question please help!!!
Here is a pic that Patton often puts up. Hope it helps...
Last edit: 22 Jun 2009 05:55 by Bluemeanie.
22 Jun 2009 09:32 #301330 by CPUCK
Replied by CPUCK on topic 1981 kz650 carb. question please help!!!
yes that helps alot, thank you much.
30 Jun 2009 12:52 #303395 by CPUCK
do you even need to have tubing for the over flow or will the fuel just evaperate?
30 Jun 2009 12:55 #303397 by fixer5000
Replied by fixer5000 on topic 1981 kz650 carb. question please help!!!
you dont want fuel falling down on a hot motor do you?? id replace them
1978 kz650b pretty much stock
massachusetts
30 Jun 2009 12:59 #303401 by CPUCK
lol ya your right, where do you connect the overflow to? underneath the motor??
30 Jun 2009 13:04 #303402 by CPUCK
lol ya your right, so where do you connect the tubing for the over flow? underneath the motor? im new to this whole deal.
30 Jun 2009 13:09 - 01 Jul 2009 02:09 #303405 by Patton
Replied by Patton on topic 1981 kz650 carb. question please help!!!
Usually bundled together and routed over the swingarm on right side to exit underneath the bike.
Good Luck! :)
Edit -- not "over" the swingarm, but over rear of engine between engine and swingarm.
Last edit: 01 Jul 2009 02:09 by Patton.
30 Jun 2009 14:18 - 30 Jun 2009 14:19 #303413 by JMKZHI
Replied by JMKZHI on topic 1981 kz650 carb. question please help!!!
The carb overflow tubing & battery vent tubing should be routed behind the engine and forward of the swingarm & centerstand & away from the drive chain.
Last edit: 30 Jun 2009 14:19 by JMKZHI.
30 Jun 2009 17:49 #303463 by Patton
30 Jun 2009 18:24 #303472 by CPUCK
awesome thanks for the help, i think i have conquered this hurdle. now im having problems with the wiring harness. im posting another post for that problem if any of you would like to help with that!!! :woohoo:
