Drilling out jets
  • otakar
  • otakar's Avatar
Re: Drilling out jets
20 Jun 2009 05:15
#300866
There are only three types of Mikuni main jets you can use. Even though they are interchangable, most guys prefer the ones with the larger head. The part # is N100.604 You can however use the small head ones also, part #N102/221 The best place to get ANY carburetor part is SUDCO 800-998-3529
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Darkangel
  • Darkangel's Avatar Topic Author
21 Jun 2009 20:39
#301207
believe it or not...I put the carbs, today road the bike...and it was rode very well...no popping at all...But off the line take off power was not were i want it too be, plus it wasn't as powerful as i want it during acceleration....so i will do the jetting, and then a sync! BTW anyone got instruction on doing a carb sync the correct way?
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
  • Darkangel
21 Jun 2009 21:09
#301211
ok guys...on monday i am going to order my colortune, and i will be order from sudco 4 of each.
52.5 Pilot Jet
140 Main
what do you guys think?
  • Darkangel
22 Jun 2009 09:45
#301335
anybody?
  • vmx540fan
  • vmx540fan's Avatar
22 Jun 2009 20:44 - 22 Jun 2009 20:53
#301463
I drilled my primary Main Jets from .024 inch to .026 inch last night. I no longer need to run the choke to get it to run right. I did not drill the secondary main jet since it was at the bottom of the needle valve emulsion tube and would not affect the fuel flow except when the variable venturi was wide open.
I also found an air filter at the local NAPA store that fit right into the original air box. It is part number 7-08300. They listed application as Techumseh 36046. It was only $6 instead of $15 for a 11013-1039 from Kawasaki. I have an OEM part coming so I can do a comparison when it arrives next week.
Here is how I do a carb sync with good results:
kzrider.com/index.php?option=com_docman&...d&gid=215&Itemid=108
1982 KZ305 B1 CSR Belt
Riding street bikes since 12 Jun 2009
Riding dirt bikes since June 1973
Last edit: 22 Jun 2009 20:53 by vmx540fan.
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
23 Jun 2009 04:14
#301500
Sounds like a good place to start.
Build Thread
  • caffcruiser
  • caffcruiser's Avatar
24 Jun 2009 19:35
#301874
Old Man Rock wrote:
NOTE: Yeah I know, who but a few has an extra set of carbies laying around....
I have about 5 sets.
Seriously. lol
(I've owned a LOT of KZ650's. :D)
  • DoubleDub
  • DoubleDub's Avatar
24 Jun 2009 20:55
#301889
I would do the carb sync even before jetting, personally.
  • anarki650
  • anarki650's Avatar
24 Jun 2009 22:52
#301909
There was a big modification to intake and exhaust that happened here. Syncing carbs isn't going to do him a dick lick of good until the jetting is close. If the situation was close to stock set up I'd agree, but with the drastic change in intake and exhaust the jetting needs to be changed before syncing will help at all...
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • Darkangel
25 Jun 2009 10:54
#301996
Well I have already order the 140 mains, and I will see how the bike responds to that...I also changed the oil, and new plugs....So if she takes off like a bat out of hell...then we'll call it good. When I pulled my plugs...they were black with white at the tip...so they were firing very well.
