rebuilt 28's. poppin thru pod filters! why?
- old_skool_77
- Woot Woot
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
- Thank you received: 797
poppin back through the filters is tellin me the intake valve isn't closing at the right time or properly.
any other symptoms?
leon holmes
- KOOL RYDER
- KZ 650B2 / KZ 1000E
Check the vaccume tube for cracks. Is it hooked up properly?
If you are not running a vacume style, is the vaccume port blocked off properly?
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
- Thank you received: 2098
And also assure that automatic ignition timing advancer is fully functional, readily moving back and forth without sticking or hanging. Might need cleaning and lubing.
Good Luck!
- keith1
I got a 79 kz motor on a 75 frame. Just had carbs rebuilt and I have pod filters and a baffeld vance and hines true sidewinder exhaust. Problem is I have some poppin coming through the filters at cruising speed in all gears. doesn't do it when im on the throttle. I have 127.5 mains and I think 117 pilots. Anyone let me know why this may be and possibly a solution to fix? Also i put brand new carb boots and clamps on the motor, so no air leaks from there.
these are vm series carbs? 28 mm?....it could be me or that its late, but those jet numbers dont seem right.....sounds like the ghost of wg fishing....
- old_skool_77
- Woot Woot
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
- keith1
carbs are stock from the 79 motor. as far as I know, the 79 and 80 model came with the acc pump on thes carbs. But I'm not 100% on that. all vaccum lines have been replace with new ones and as far as I know they should be working properly. petcock is a dual feed. carbs have only one fuel intake line on them, so only one of the feeds on the petcock is being used and the other is blocked of. it does leak a little from the blocked off side, from the clamp not being tightend. possibly the culprit? I have dyna 3 ignition and coils. also when I hammer on the throttle, I get this pinging type noise coming from the engine, hence maybe an outtawack valve?:huh:
are you sure about previously stated main and pilot jet numbers?
- old_skool_77
- Woot Woot
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
- keith1
yeah im sure. the shop that rebiult them told me the size should be fine. they are stock for that carb. i was actualy gonna raise em up to 130 mains and 120 pilots but the carb guy told me that the stock ones should be fine. but i was kinda sketchy.
130 mains and 120 pilots on a vm series 28 mm carb
mounted on a 1000 cc motor? sketchy is an understatement....maybe another member can help.......
am i the only one this doesnt make sense to?....?????????
... when I hammer on the throttle, I get this pinging type noise coming from the engine, hence maybe an outtawack valve?:huh:
Pinging -- Pinging under load ???
Possibly predetonation (spark knock)? If not already done, would read sparkplugs (any tiny aluminum balls?) Possible incorrect ignition timing? Wrong plug heat range? Might burn hole in piston. :pinch:
Good Luck!
- old_skool_77
- Woot Woot
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
- old_skool_77
- Woot Woot
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
