rebuilt 28's. poppin thru pod filters! why?
  • old_skool_77
  • Topic Author
  • Woot Woot
20 May 2009 13:07 - 20 May 2009 13:22 #292905 by old_skool_77
rebuilt 28's. poppin thru pod filters! why? was created by old_skool_77
I got a 79 kz motor on a 75 frame. Just had carbs rebuilt and I have pod filters and a baffeld vance and hines true sidewinder exhaust. Problem is I have some poppin coming through the filters at cruising speed in all gears. doesn't do it when im on the throttle. I have 127.5 mains and I think 117 pilots. Anyone let me know why this may be and possibly a solution to fix?:unsure: Also i put brand new carb boots and clamps on the motor, so no air leaks from there.
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
Last edit: 20 May 2009 13:22 by old_skool_77. Reason: forgot to add a comment
20 May 2009 14:18 #292920 by 531blackbanshee
Replied by 531blackbanshee on topic rebuilt 28's. poppin thru pod filters! why?
was it fine before the carb rebuild?
poppin back through the filters is tellin me the intake valve isn't closing at the right time or properly.
any other symptoms?
leon holmes
  • KOOL RYDER
  • KZ 650B2 / KZ 1000E
20 May 2009 15:04 #292926 by KOOL RYDER
Replied by KOOL RYDER on topic rebuilt 28's. poppin thru pod filters! why?
Are you running a vaccume style petcock?
Check the vaccume tube for cracks. Is it hooked up properly?
If you are not running a vacume style, is the vaccume port blocked off properly?
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
20 May 2009 15:28 - 20 May 2009 15:31 #292933 by Patton
Replied by Patton on topic rebuilt 28's. poppin thru pod filters! why?
If not already done, would assure valve clearances being to specs.
And also assure that automatic ignition timing advancer is fully functional, readily moving back and forth without sticking or hanging. Might need cleaning and lubing.
Good Luck! :)
Last edit: 20 May 2009 15:31 by Patton.
20 May 2009 18:48 #292979 by keith1
Replied by keith1 on topic rebuilt 28's. poppin thru pod filters! why?
these are vm series carbs? 28 mm?....it could be me or that its late, but those jet numbers dont seem right.....sounds like the ghost of wg fishing....
  • old_skool_77
  • Topic Author
  • Woot Woot
20 May 2009 19:00 #292982 by old_skool_77
Replied by old_skool_77 on topic rebuilt 28's. poppin thru pod filters! why?
carbs are stock from the 79 motor. as far as I know, the 79 and 80 model came with the acc pump on thes carbs. But I'm not 100% on that. all vaccum lines have been replace with new ones and as far as I know they should be working properly. petcock is a dual feed. carbs have only one fuel intake line on them, so only one of the feeds on the petcock is being used and the other is blocked of. it does leak a little from the blocked off side, from the clamp not being tightend. possibly the culprit? I have dyna 3 ignition and coils. also when I hammer on the throttle, I get this pinging type noise coming from the engine, hence maybe an outtawack valve?:huh:
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
20 May 2009 19:17 #292989 by keith1
are you sure about previously stated main and pilot jet numbers?
  • old_skool_77
  • Topic Author
  • Woot Woot
20 May 2009 19:23 #292991 by old_skool_77
yeah im sure. the shop that rebiult them told me the size should be fine. they are stock for that carb. i was actualy gonna raise em up to 130 mains and 120 pilots but the carb guy told me that the stock ones should be fine. but i was kinda sketchy.
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
20 May 2009 19:50 - 20 May 2009 19:53 #293000 by keith1
130 mains and 120 pilots on a vm series 28 mm carb
mounted on a 1000 cc motor? sketchy is an understatement....maybe another member can help.......
am i the only one this doesnt make sense to?....?????????
Last edit: 20 May 2009 19:53 by keith1.
20 May 2009 20:02 #293002 by Patton
old_skool_77 wrote:
... when I hammer on the throttle, I get this pinging type noise coming from the engine, hence maybe an outtawack valve?:huh:
:unsure: Pinging -- Pinging under load ???
:unsure: Possibly predetonation (spark knock)? :unsure: If not already done, would read sparkplugs (any tiny aluminum balls?) Possible incorrect ignition timing? Wrong plug heat range? Might burn hole in piston. :pinch:
Good Luck! :)
  • old_skool_77
  • Topic Author
  • Woot Woot
20 May 2009 20:53 #293011 by old_skool_77
the plugs are stock which and they are B8ES NKG brand. they are new. i dont hear anything out of the ordinary when i ride normaly. only when i lean foward to hold on and hit the gas is when i hear it. when im toolin along at cruising speed in any gear is when i get some poppin outta the air pods. doesnt do it when im under load.
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
  • old_skool_77
  • Topic Author
  • Woot Woot
20 May 2009 20:55 #293012 by old_skool_77
took this bike to have carbs rebuilt and tuned properly at a bike shop. should I take it back???
1975 z1 900
1976 kz 900
1977kz 1000
1980kz 1000 ltd
