Is this right?
- sbulla
- 1980 KZ1000 LTD
Is this extra length going to be a problem?
Sonny
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
- Thank you received: 2098
Was a larger needle jet also included in the Dynojet kit?
Good Luck!
- sbulla
- 1980 KZ1000 LTD
Perhaps an optical illusion :huh: or just my imagination :S , but the Dynojet needle appears physically thicker than the stock needle, whereby the Dynojet needle would result in leaner mid-range fuel mixture than the stock needle.
Good Luck!
There is a bit of a shadow on the pic. They are the same thickness at the top. Only the needles w/clips and shims and a couple of main jet sizes were in the kit.
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- loudhvx
- Thank you received: 1616
Here's a drawing I did of the 550 A/C/D needles for comparison.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Measuring equal distances from the clip position, the respective girths between the two needles could be compared to determine which affords the thinner taper (for richer mixture).
May require a micrometer as opposed to caliper.
Good Luck!
Edit -- Sudco manual shows many different sizes and shapes of jet needles.
- loudhvx
To be richer, the taper portion of the jet needle inside opening at top of needle jet must be thinner at any given throttle slide position.
I used a mic. But it's tricky on a tapered diameter. I didn't have an attachement for the mic. to measure with, I had to use the edge of the mic. jaws. Luckily I had a decent Starrett at work.
1981 KZ550 D1 gpz.
Other links.
- Jeff.Saunders
www.z1enterprises.com
Z1 Ent on Facebook,
- sbulla
- 1980 KZ1000 LTD
I struggle to understand the Dynojet kit for the 77-80 KZ1000. It's a "one size fits all" kit - yet you have a signifcant variation in setup on the 1000's - not only the standard and LTD models, but the shaft bike and Z1R - all supposely covered by the same kit. With one KZ1000 I bought, the PO installed a Dynoket kit and it would not run right with the jet kit - I seem to remember the slides had been drilled - I know I ended up swapping the carbs out for a different set to get the thing running well..
I kinda wondered about that application also as the kit I have says it covers 78-80.
I have an e-mail into Dynojet support for more info and am waiting to hear from them.
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
show ---
USA models with needle 16009-1032 5CN17
and jet 16017-1035 AO-4
Canadian models with needle 16009-1013 5CN15
and jet 16017-1011 O-1
Canadian needle appears to have 5 clip positions.
USA needle isn't very clear, but maybe only a single clip position.
Just guessing the Canadian needle might be thinner (richer) and/or jet larger (richer) because of USA's strict EPA regs at the time. But really haven't a clue as to comparison between the two needle sizes or between the two jet sizes.
Perhaps Canada model got a thinner needle and/or a larger jet affording a richer more responsive mid-range.
Wondering whether oem Canadian needle and/or jet might be currently available, as perhaps a better option than the Dynojet needle.
Good Luck!
- loudhvx
USA fixed clip.
Elsewhere adjustable clips.
USA mixture screws sealed under plug.
Elsewhere adjustable mixture.
1981 KZ550 D1 gpz.
Other links.
- sbulla
- 1980 KZ1000 LTD
kawasaki.com carb parts diagrams for 1980 KZ1000-A4
show ---
But, mine's a KZ1000-B4 with a 5CN29 needle. Maybe that's where Dynojet (or me) messed up. Didn't specify the LTD model.
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- Dragone
