Can't get the #$%@#%@#$% Carbs off!
07 May 2009 08:34 #288726 by Trebek
Can't get the #$%@#%@#$% Carbs off! was created by Trebek
I am in the process of replacing my carbs on my kz650. I've unbolted everything that the manual says to, but the 30 year old rubber boots leading to the engine and airbox is as hard as a bowling ball.
Hopefully I don't have to break out the saw.:woohoo:
07 May 2009 08:36 #288727 by PLUMMEN
Replied by PLUMMEN on topic Can't get the #$%@#%@#$% Carbs off!
i bet z1 enterprises could sell ya some soft new ones B)
07 May 2009 08:42 #288728 by Russ Jackson
Replied by Russ Jackson on topic Can't get the #$%@#%@#$% Carbs off!
You might try a sharp wood chisel and kind of cut through them....Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
07 May 2009 08:43 #288729 by buckinrut25
Replied by buckinrut25 on topic Can't get the #$%@#%@#$% Carbs off!
remove the 10mm bolts that hold air box to frame should give enough slack to remove carbs or if you have a heat gun you can soften the boots for a short time but its kinda of a pain
  • The Gringo
  • ¡Usted no necesita otra motocicleta!
07 May 2009 09:16 #288737 by The Gringo
Replied by The Gringo on topic Can't get the #$%@#%@#$% Carbs off!
If they are that hard don't torture yourself, just cut them off with a hacksaw and order new ones from Z-1 Ent. When you have to put them back on you'll be glad you did.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • osride
  • Blog: http://classicmotorbikes.blogspot.com/
07 May 2009 09:20 #288740 by osride
Replied by osride on topic Can't get the #$%@#%@#$% Carbs off!
New ones may be the best way to go, but I've used a hair dryer and/or a bowl of hot water to soften the rubber boots up enough to make them flexible. Just be careful you aren't putting leaking fuel onto a red-hot hair dry (sorry for stating the obvious). :unsure:
07 May 2009 09:50 #288742 by anarki650
Replied by anarki650 on topic Can't get the #$%@#%@#$% Carbs off!
+1 on all the advice...
If they're that hard the odds of them leaking when you reinstall the carbs are very very very very good.
I'd take a heat gun to them to soften them up enough to spit the carbs out and then order a fresh set straight away to put on before you put the carbs back on.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
07 May 2009 09:59 #288745 by Trebek
Replied by Trebek on topic Can't get the #$%@#%@#$% Carbs off!
Excellent advice all. I'll order new ones and cut the old ones off with a hacksaw. I'm sure I'll have more questions, since I've never replaced a carb bank before.
07 May 2009 19:51 - 07 May 2009 19:52 #288918 by Bluemeanie
Replied by Bluemeanie on topic Can't get the #$%@#%@#$% Carbs off!
I messed with my old ones and actually melted one in the microwave trying to soften it up. New ones are like night and day. Install carbs and then feed boots thru air box onto carbs. I ordered fesh new shiny spring clamps for them too! :)
Last edit: 07 May 2009 19:52 by Bluemeanie.
  • trianglelaguna
07 May 2009 20:43 #288947 by trianglelaguna
Replied by trianglelaguna on topic Can't get the #$%@#%@#$% Carbs off!
igot new clamps too from z1e also...nice clean ,tighten great and look tits...way cheap money for how good they are too....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
11 May 2009 09:20 #290187 by Trebek
Should I get the new airbox boots or the rubber that goes to the intake? I really can't afford both right now.
11 May 2009 09:55 #290193 by Link14
Replied by Link14 on topic Can't get the #$%@#%@#$% Carbs off!
If you can only get one set, my vote would be the airbox hoses. You can install the carbs, then feed the hoses through the airbox and install them with the carbs on.
