- Thank you received: 225
CA/AZ KZ with CR Specials Jetting for Emissions?
- Old Man Rock
Now before you all get your big girl panties in a bind , I realize not every motor is going to be the same due to elevations, regional temperatures, head/valve work, intakes, vacuums, carb size, exhaust etc....
Anyone out there with similar setup...
Motor upgraded to 1015cc.
Cams: WebCam .365 lift, 283 duration, 246 duration @ .050
Head: Valve 3 way grind with port & polish via Cavanaugh Racing Heads.
Carbs: Keihin, 29mm CR specials, Dynoman Filter PODs
Kerker 4 to 1 exhaust with 1.5" competition baffle.
Dyna S electronic ignition and coils.
AZ Emission Test Measurement:
The test is basically only an idle test. They have you at idle for ~ 15 seconds for a first reading then they have you up the rpm to 2500 for ~ 15 seconds and back to idle for a second reading.
Hydrocarbons (HC) in PPM: Standard is 1800: Pass @ 1145
Carbon Monoxide (CO) in %: Standard is 5.50: First idle was 7.91, Second Failed @ 8.12
Curious what you ended up in jetting for passing emissions in your area... Especially for those of you in CA.....
Thanks,
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Bluemeanie
- Thank you received: 14
- Old Man Rock
... :ohmy: :huh:don't have emission testing for bikes here in CA
Hell, I would have thought CA would do to all the EPA and tree hugging ways of thinking out there.... :laugh:
NOTE: I was born and raised in Northern Cal....
see my smog guy and do "your" tast and see if my bike would pass AZ standards
If possible, that would be cool to know.... Thanks!
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
- Old Man Rock
For 3/4 plu I have gone from a 120 to 115 main jet.
I was just curious what otherrs have come across in their configurations.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Royal1MC
- Is it just me, or is it just great to be on a KZ
www.abate.org/
but this what I found for California:
Introduced in the Senate in late February, SB 435 targets bikes with illegally modified exhaust systems and would go into effect in 2012 if passed and signed by Gov. Arnold Schwarzenegger, an avid motorcyclist. Biennial smog checks would be required for motorcycles manufactured in the 2000 model year and later under a bill making its way through the California Legislature
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
- Tyler
- Thank you received: 92
"74 Yamaha DT 400 Enduro
- Tyler
OMR, you could try burning a mixtrure of 50% alchol and 50% gasoline, just for the purposes of your test. IF you can jet the bike rich enough to run. Again just thinking...
- Old Man Rock
There's actually a funny story to it....
As mentioned, drop to number 3 on the needle jet clip and I installed the 58 slow jets this afternoon.
In using the color tune, due to the 58's, goes from yellow .5 turn out to bunson blue at 1.5 turns out.... So 1 to 1.25 turns out (half way between the two is about correct ...
With this in mind, I tweaked her out as far as possible, popping out the pipe so backed her out about 1/8th turn....
Drive to emissions, ran like shit lol, where they have you shut her down then start her up for idle test.
SOB wouldn't start so I had my screw driver and oh no, you can't do that... Ok, so went for the choke, oh no you can't do that... WTF you sonsabitch...
Ok, if I roll it out of the bay, make my tweaks and come back... She replies, No problem! ROFLMFAO.... So for emissions, 2.75 turns out will do it...
Out the bay I go.... Tweak her back about 1/4 turn, adjust the idle and back into the bay I go... Old girl flew through with no problems...
As mentioned, CO% Standard is 5.5%.... Measured in at 2.80% SWEET!!!!
Once out the bay, tweaked her back to 1.25 turns out and took her for a drive... Twist the throttle and she screams nicely with no back fire... I'll keep my eye on the plugs.....
Anyhoot.... Thanks again all...
For future reference....
Kehins CR Specials:
Main Jet: 115
Slow Jet: 58
Needle Jet position # 3:
Pilot adjust 2.75 turns out for emissions.....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- larrycavan
- Visitor
- Old Man Rock
Ok, basically lie my ass off, lean her just for the test and get the hell out of there to put her back where she likes it.... :laugh:
Dyno... yup!
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
