79 KZ1000 ST - Won't idle below 2K?
- tsar
02 May 2009 10:29 #287197
by tsar
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
______________________
1979 KZ1000ST
2001 HD Sportster 1200
1996 Vulcan 1500
Montreal,Canada
79 KZ1000 ST - Won't idle below 2K? was created by tsar
We have just recently rebuilt the top end and the carbs to stock on my ST.After we got her all back together ,it starts up fine but won't idle under 2k.It has pod filters and a two brother carbon fiber exhaust( I cut the Kerker and welded on the 2 Brothers),Main jets were changed to compensate for extra air flow and it has a vacuum petcock.when we turn down the Idle screw below 2K, it dies. We have tried everything.Please Help.
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
- chevyhead
02 May 2009 10:35 #287199
by chevyhead
Replied by chevyhead on topic 79 KZ1000 ST - Won't idle below 2K?
have you tried to richin your fuel mixture???? with the pods you might be getting more air therefore making it run lean????
- buckinrut25
02 May 2009 10:44 #287202
by buckinrut25
Replied by buckinrut25 on topic 79 KZ1000 ST - Won't idle below 2K?
you might need to go to a richer pilot jet id try to move the clip on the needle valve to a richer setting first if its not adjustable i have found shimming them with a 3mm flat washer works also just do any changes a little at a time
- tsar
02 May 2009 12:06 - 02 May 2009 12:13 #287209
by tsar
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
Replied by tsar on topic 79 KZ1000 ST - Won't idle below 2K?
We tried richin the fuel mixture with no effect.
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
Last edit: 02 May 2009 12:13 by tsar.
- tsar
02 May 2009 12:07 - 02 May 2009 12:14 #287210
by tsar
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
will try the 3mm washers and see if that works.
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
Last edit: 02 May 2009 12:14 by tsar.
- tsar
02 May 2009 12:11 #287212
by tsar
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
Also noticed that the carbs have 2 vacuum lines , One for the petcock and I believe the other went to the original airbox. What should we do with the second vacuum line? Just plug it up or what?
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
- timebomb33
- Thank you received: 10
02 May 2009 12:51 #287215
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 79 KZ1000 ST - Won't idle below 2K?
you will need to take the carbs back off and reclean them the pilot cicuits not just the pilots are plugged you will need to take spray carb cleaner and spray thru the passages and jets and then follow up wit compressed air and make sure you get air blowing out the passages if you don't keep doing it until you do that is the main reason it will not run off the enrichner circuit.
- Thank you received: 2098
02 May 2009 13:54 #287225
by Patton
Replied by Patton on topic 79 KZ1000 ST - Won't idle below 2K?
Would also assure correct ignition timing and that advancer unit is fully returning to F mark alignment at idle rpm.
Good Luck!
Good Luck!
- timebomb33
02 May 2009 13:57 #287226
by timebomb33
don't worry about changing needle heights that will only have an effect on the midrange just worry about your pilot circuits. also make sure the vent passage in the bowl is clean and air will shoot out of that cleanly.
- tsar
04 May 2009 08:46 #287795
by tsar
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
Ok Guys will try cleaning the pilots this week. Thanks.
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
- tsar
13 May 2009 18:54 #290940
by tsar
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
:laugh: I GAVE UP! I took them off and gave them to the local speed shop,Just couldn't get the dam things to behave.Thanks for all the info guys i really appreciate it.The season is too short up here in the Tundra to be screwing around with carbs.Those who can't do,PAY!:laugh:
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
- Bdog
- Sweep the leg johnny!!!
- Thank you received: 9
13 May 2009 19:49 #290970
by Bdog
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
Replied by Bdog on topic 79 KZ1000 ST - Won't idle below 2K?
One more thing to check, boots. On mine the boots were warped and I got too much vacuum and it blew out the fire in no. 1 cylinder. Check that.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
