Where do these hoses go?
- Requiescat
01 May 2009 17:51 #287042
by Requiescat
1980 KZ750H LTD more fun than a barrel of monkeys.
have had:
1982 Suzuki GS400L (wadded by an ex friend).
1982 CB 750 Nighthawk(sold to a friend).
Where do these hoses go? was created by Requiescat
1980 KZ750H LTD
I've finished putting the carbs back on and pulled out the box of hoses that I got with the bike.
Carburetors #2 and #3 have two spots where a hose must attach. #1 and #4 are plugged. I can't find anything in Clymer, The bike won't start, it seems like it's going to catch, then no dice.
This is the Canadian version, there isn't an air suction system. Can anyone point me to a schematic or a diagram?
Tx
Requiescat
Tx
Requiescat
have had:
- Bdog
- Sweep the leg johnny!!!
- Thank you received: 9
01 May 2009 18:07 #287047
by Bdog
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
Replied by Bdog on topic Where do these hoses go?
Sounds like vacuum ports, that would make it harder to start. Plug them with the same size as #1 & 4. Does the carbs petcok have vacuum actuated fuel flow? Keihen carbs?
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- Silver
- Old Bikes Are Better!
01 May 2009 18:09 #287048
by Silver
1983 KZ750F1 LTD
Replied by Silver on topic Where do these hoses go?
Plug em and see if it starts.Vaccum Petcock?
1983 KZ750F1 LTD
- Requiescat
01 May 2009 18:22 #287050
by Requiescat
have had:
Replied by Requiescat on topic Where do these hoses go?
Yes it's a vacuum petcock. I'll make sure there's vacuum going to it.
Thanks
Thanks
have had:
- Requiescat
01 May 2009 18:22 #287052
by Requiescat
have had:
I'll plug them up and hope it starts.
Thanks.
Thanks.
have had:
- Requiescat
01 May 2009 18:40 #287059
by Requiescat
have had:
It starts but it won't stay started, I think I have to
adjust the idle speed adjuster. Sun is going down, I'll finish getting this bike on the road tomorrow.
Thanks
Thanks
have had:
- cannondalemtb
04 May 2009 01:07 #287746
by cannondalemtb
Replied by cannondalemtb on topic Where do these hoses go?
I think I had the same problem. I even had a hose attached to one of them. I ended up routing the hose to the other one so that they are just connected by one hose.
- N0NB
- Blue handles better
04 May 2009 04:19 #287749
by N0NB
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
Replied by N0NB on topic Where do these hoses go?
Those sound like the bowl vent hoses to keep the carb bowls at atmospheric pressure. They are not vacuum hoses as #2 has that port and it is deep in the rack whereas the vent hoses are almost centered over the bowls.
The hoses simply route back over the top of the front of the air box and down a ways along the frame tube. Without these open to the atmosphere, there is no way for the fuel to be pushed up into the carb throat due to the lower than atmospheric pressure in that area when the engine is running. Also, the vents are necessary so the bowls can fill with fuel from the tank by allowing the air to escape.
Nate
- AXL
04 May 2009 05:59 #287758
by AXL
Replied by AXL on topic Where do these hoses go?
pics would help. once the bike IS started the carbs need synchronized.
