- Thank you received: 9
vacuum leak?
- Bdog
- Sweep the leg johnny!!!
01 May 2009 17:05 #287027
by Bdog
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
vacuum leak? was created by Bdog
would a vacuum leak be enough to make a cylinder not fire? The motor also won't settle after it warms up, hovers around 3000 intermittenly. weird
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- timebomb33
- Thank you received: 10
01 May 2009 17:09 #287030
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic vacuum leak?
the simple answer to this is yes it could definitly cause both of your problems
- Bdog
01 May 2009 18:05 #287045
by Bdog
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
Replied by Bdog on topic vacuum leak?
I noticed a gap between the carb holder and the intake side of the head. Applied a little rtv to seal the gap to prove the problem.Other than new holders, what is a better fix?
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
