cleaning a whole rack of carbs?
- rkan
1978 KZ650B
- shighley
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
- keith1
- Thank you received: 2
Bicycle Lee; In your first post you mentioned getting 28mm carburetors. I believe the pictures you posted are 26mm single inlet pumper versions. If I'm correct, the 28's have two screws on the caps and the 26's have three. I need to know if I'm wrong about this because I'm bidding on a set as I type. Either way, you need to know for jetting. Please straighten me out on this one and ride safe, Steve
26 s and 28 s from the same basic time frame have 3 screws holding on the tops....he could very well have 26 pumpers...the only way to really know is measure across the engine side inside diameter.....
- Bicycle Lee
1978 KZ1000 police
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Bicycle Lee
rkan try not to use those carb soak kits as only a last resort you have to remove all rubber componets as the carb soak will deform and destroy the rubber wich usally means completely spliting the carbs apart and removing every componet making sure that you get any rubber parts out.
I was thinking the same thing, and since all the rubber parts of these ones seem fine, I figure why fiddle with it.... and potentially fiddle it up? Haha
1978 KZ1000 police
- harm
- Tom
- Thank you received: 13
good luck!
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- Bicycle Lee
when you say O rings, do you mean the rubber hoses themselves? the little wire hose clamps? What do you mean?I have done the lemon juice thing with great results and would recommend it if doing a complete tear down. From the pics you posted i think i would remove the bowls/jets and clean w/ aresol carb cleaner and compresed air as previously stated. If you do tear them down make sure you replace the o-rings on the fuel tubes that connect the carbs.
good luck!
And do you mean, do the aerosol cleaner thing and THEN boiling the lemon juice thing? Should I remove the floats as well?
1978 KZ1000 police
- anarki650
- Thank you received: 5
The O rings are inside the carb assemblies, and if you dip in a carb cleaner or other chemical such as that the rubber gets eaten away right along with the crud that's gumming up your carbs. With lemon juice you don't have to worry about that, so you don't have to tear the carbs down off the rack and replace those (unless you've already got bad O rings that are leaking fuel). IMHO you should get yourself a big roaster (one of those cheap tinfoil ones would do the trick) and enough lemon juice to cover the carbs (find a cooking supply store near you, you'll be able to get large quantities of lemon juice cheap there). Set up a burner outside(side burner on a grill would work, so would a little propane camp stove) and boil them bad boys out.
I'd pull the bowls and top covers, remove the slides if they are free, pull the floats and needles, and then boil the rest for 15 minutes. Rinse them real good afterwards and dry with compressed air. Put the bits back together and you're golden.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- timebomb33
- anarki650
09 Kawasaki ER6n
Omaha NE
- harm
- Tom
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
