Fuel Air Mixture
- zimmey356
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- zimmey356
- Thank you received: 2098
Good Luck!
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- timebomb33
Sounds like no fuel to mix. Have you pulled the fuel line from the petcock to see if fuel is getting to the carbs. Maybe a clogged fuel filter?
And is there plenty of gas in the tank? And not needing to go on "reserve" (if the petcock is fully functional). Or maybe the petcock is clogged. Or the petcock screen up inside the tank is clogged.
Good Luck!
- zimmey356
Well when I put it on primary it starts but won't stay so the fuel is coming....or should i check it a different way
Could loosen or remove carb float bowl drain screw and see whether fuel flows freely out the drain. This will at least show whether or not fuel is getting into the floatbowl.
Good Luck!
- zimmey356
- timebomb33
- bill_wilcox100
- Thank you received: 5
Best of success.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
