- Thank you received: 10
Runs only when on Full Choke...please help
- timebomb33
13 Mar 2009 21:54 #271770
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Runs only when on Full Choke...please help
yes that is the fuel screw the pilot is located in the bowl also the main jet and the neeedle jet as well, the pilot jet is the smallest jet and also the smallest passage so it can be plugged very easily the fuel screw is used for fine adjustment of the idle mixture so it won't be the major problem pull the bowls and start by unscrewing all the jets and checking them out for obstructions and blockages by the way the bowls should not be green in side.
- Mindcake
- http://www.skydivemichigan.com/
17 Mar 2009 16:40 #272824
by Mindcake
81 KX750 Ltd , 77 KZ650, 01 955 Sprint St
Replied by Mindcake on topic Runs only when on Full Choke...please help
OK, so today I cleaned and rebuliT, the carbs with the kit I got from Z1, man was that necessary, pretty much everything that came into contact with gasoline needed to be replaced or cleaned (and it had both kinds of gum....white and rusty...lol). After rebuilding the carbs the bike would idle nicely, but if you drop it into gear and try to take off it feels like there is no power. I rechecked the timing and it was off a little but when I try to retard or advance even a small amount the bike dosent want to start or run. Tomorrow I will check the Valve adjustment and start from scratch on timing the bike again.
Also I am using the motor from a 78 but the points set that came on the 77, the cam the dictates when the points fire is also from the 77 (as the 78 had EI) now is there anything different between the 78 and the 77 as to where that piece indexes on the crank?
Thanks again
Jim
Thanks again
Jim
- OKC_Kent
- Thank you received: 20
17 Mar 2009 18:22 #272851
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic Runs only when on Full Choke...please help
The part you mention is the advancer, and are the same partfrom 77 and 78.
Oklahoma City, OK
- Mindcake
17 Mar 2009 20:29 #272896
by Mindcake
dissappointing as it definatly had electronic ignition on what I was told was a 78 engine....but it might be aftermarket, I say that because the wire colors dont match the colors on any of the wiring diagrams I have seen. it was something like 2 whites 1 pinkish and 1 black, Ill take some pictures tomorrow.
- timebomb33
17 Mar 2009 20:33 #272899
by timebomb33
sounds like you have a dyna ignition which is a good thing much less problems than points once they are set properly they won't need anything else.
- Mindcake
17 Mar 2009 21:25 #272946
by Mindcake
well thats good but now I will also need to find a wiring diagram and adapt it to my bike if possible
- timebomb33
17 Mar 2009 21:38 #272952
by timebomb33
dyna tek has an excellent website and you can get installation and trouble shooting downloads from them for your specific ignition system just look up dynatek.com
- Mindcake
18 Mar 2009 14:45 #273160
by Mindcake
Wasent a Dyna EI it started with a M but have forgotten the name now :S either way today was my last day of being able to work on it so I took it in to the shop. I feel defeated......
I will post what the mechanic finds when I get a call
Thanks for the help
Jim
Thanks for the help
Jim
- KawiConvert
- Thank you received: 4
18 Mar 2009 15:30 #273169
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic Runs only when on Full Choke...please help
One question that I may have missed, but what jet sizes do you have? I ask this because I noticed the pods and didn't know if you had rejetted for this. My 650 did the same kind of behavior where I could use the choke as a throttle and later at low RPM's it would die. Just wanted to check.
- timebomb33
18 Mar 2009 19:09 #273216
by timebomb33
its an old martek and they aren't in bussiness anymore you will if the ignition is the problem have to either get a points plate from someone or buy a dyna s which is what i would do the martek came out around the same time as your bike was hatched so it has given good service it's only about 30 years old. if you go with apoints plate you will probably need points and condensers as well so it will be just as cheap to go with the dyna system and easier to deal with as well.
- OKC_Kent
18 Mar 2009 20:38 - 18 Mar 2009 20:44 #273262
by OKC_Kent
Oklahoma City, OK
Maybe it's a Martek. That's old school stuff, haven't heard of them in years.
Edit: what timebomb said, but better than I could say it.
Oklahoma City, OK
Last edit: 18 Mar 2009 20:44 by OKC_Kent.
- Mindcake
19 Mar 2009 15:58 #273517
by Mindcake
Nice call timebomb, I put the points from the origional 77 motor in this motor same holds true for the stator, because I diddnt want to do a lot of messing with the electrical system....at least not yet
